Results 1 to 7 of 7
Thread: looking at an 85 GLC need some help!
    Feb 2009
    A rainy state of mind, WA
    151
    Taking a look tomorrow at an 85 GLC. I think its a cool little car with some potential but as this would be the first time laying hands on anything outside the Toyota world, I'm a little n00b-ish as what to look for.
    Anything specific to the car or generation that I should look for or be aware of?
    Jan 2009
    Queensland Australia
    181
    rust in the rear panel below the rear hatch near the gutters, check for blocked drainage hole in the rear as well and look inside the rear part so you're looking at the back of the tail light behind the carpet feel up under the gutter and look for rust.
    Dec 2008
    Athens, Greece
    98
    Get a compression test!
    Feb 2009
    151
    compression test recently done by owner and looks fine on all cylinders, will take a look at the areas described when there today to look again!
    thanks guys!
    Jan 2009
    181
    Quote Originally Posted by ohcanada_00
    thanks guys!
    Thats great to hear but the Rx7's dont have any cylinders! :twisted:
    Rotors maybe but not cylinders! :lol:
    Jan 2008
    Villeneuve, Qld, Australia
    508
    Quote Originally Posted by rx7s2
    thanks guys!
    Says the new Mazda PISTON man!
    GLC is 323, 5 door or 3 door?
    Should be the E5 1.5 litre engine in both variants - well Oz versions anyhow. Motor wasn't too bad but you always seem to need to adjust the valves - can be noisy. Just make sure the rocker cover hasn't cracked as they can crack when tightened too much. The water pumps also seem to leak as well.
    If you can road test, keep an ear out for front wheel bearing noise, they are a little prone to wear and are quite an expensive job over here to do.
    Jan 2009
    181
    ops: thats what happens when they call things different all around the world ops: :mrgreen:
