Results 1 to 7 of 7
Thread: Corona MkII from down under
    Apr 2007
    Australia
    10
    My track car is a 1976 Corona Mk2 MX23
    Engine:
    * 2JZGE (unopened)
    * 48mm individual throttle bodies
    * mandrel bend extractors
    * Motec M800
    * 2.5" exhaust
    * 148 rwkW @ 6600 rpm
    Clutch and gearbox:
    * 4 puck 236mm ceramic clutch
    * 2100 lb pressure plate
    * W58 gearbox
    Differential:
    * Hilux RN41 G series LSD - 3.9:1
    Brakes:
    * Front - 330 x 28mm rotors
    - AP Racing CP5200 4 spot calipers
    * Rear - 307 x 18mm rotors
    - Celica ST205 2 spot calipers
    Wheels and tyres:
    * 16 x 7" ROH mags of some description (+36 offset)
    * Yokohama Advan A032 205 50 16
    Quarter mile: 13.8 @ 100mph
    Humble beginnings - as purchased from deceased estate
    Now:
    At the track.
    Hope you enjoy!
    Re: Corona MkII from down under
    That engine is just ***GASP!!!*** :shock:
    What's going on for suspension? How did you make it trackworthy??? (holy negative camber, too!!!)
    Awesome ride. Keep the stock color--looks great.
    Feb 2007
    Kent, England
    21
    Wow!
    Apr 2007
    Australia
    10
    Quote Originally Posted by gamby
    Thanks.
    I'm using 1000 lb/in springs at the front with a 30mm sway bar and 300 lb/in springs at the rear with a 22mm sway bar. I have Koni red (one way adjustable) shock absorbers in there. As for the camber, I modified the upper control arms to accept mre shimming. At the moment I can get 4.75 degrees of negative camber and 4 degrees of caster.
    Quote Originally Posted by gianttomato
    :shock:
    The whole setup sounds pretty sick. Nice.
    Oct 2009
    Pakistan
    158
    @gianttomato
    Buddy are you still around? just read the specs of your car, seems marvelous!! but unfortunately the link to the pics are dead... can you please post new links/pics...
    regards...
    Oct 2011
    Malta
    24
    hi im raypul ive been told that maybe you can help me im trying to buy a power steering box for my mx22 .do you think you can thanks in advance
  1. 71 Corona MKii *Seattle,Wa*
    By XtremeMotorworks in forum Ad / Auction Finds
    Last Post: 09-30-2013, 07:15 PM
  2. My First JNC: 74 MX29 Corona MKII
    By GZfatchiX in forum Toyota Garage
    Last Post: 05-11-2013, 01:58 PM
  3. 74 Corona MKii
    By aussiesmg in forum Toyota Swap Meet
    Last Post: 12-19-2011, 02:31 AM
  4. 1972 Corona MKII
    By white_raven in forum Toyota Garage
    Last Post: 10-18-2010, 02:58 AM
  5. WTB: 72 Corona MKII parts
    By white_raven in forum Toyota Swap Meet
    Last Post: 09-16-2010, 02:23 PM
