Results 1 to 2 of 2
Thread: Adjusting valve backlash
    Apr 2010
    washington state
    Another Dumb question:
    I've never adjusted the valves so I have a question.
    On a '70 Datsun 2000 engine;
    Do I need to trim down (Make narrower) my feeler gages to fit in the notch in the cap that the rocker rides on? I think it would be about 1/4 inch wide.
    Any input would be helpful.
    Feb 2007
    Napa Ca
    The intakes are .008 and the exhausts are .010. You can get them close cold, then warm it up and recheck. I think you need a 14mm open end for the adjuster and a 19mm for the lock nut.
    I start with the intakes, starting with #1 cyl (front of the engine) then go back and do the exhaust valves, again starting with #1.
    Hopefully you don't have something odd going on where you need larger lash pads that fit under the rocker arm on top of the valve. If your wipe pattern is off, that will cause the cam and rockers to degrade at a very fast rate. An "A" or "B" cam or even a slightly larger cam should be fine.
    Just make sure the valve is fully closed (cam lobe pointing up) and you should be good to go.
  1. Need only 1 inlet valve 2TG
    By Toyohead in forum Toyota Swap Meet
    Last Post: 02-23-2015, 07:23 PM
  2. 1980 toyota landcruiser air pump adjusting bracket w p/s
    By toyomaz2000 in forum Toyota Swap Meet
    Last Post: 02-15-2012, 06:38 PM
  3. 4ag valve covers
    By oldskoolte86 in forum Toyota Swap Meet
    Last Post: 11-03-2011, 04:41 AM
  4. need help adjusting my timing
    By jamesandoval in forum Datsun/Nissan Garage
    Last Post: 09-01-2011, 10:18 PM
  5. 2tc valve adjustment
    By onondagawoody in forum Toyota Garage
    Last Post: 04-27-2011, 03:48 PM
