Results 1 to 5 of 5
Thread: My RA22 project.
    May 2010
    California
    59
    My RA22 project.
    Here she is:
    I guess the plan for now is to someday swap in either a 20r, or a 22r. As it sits it has a 21r with a weber 2 barrel progressive carb, but this engine has like 400k miles on it, so I think the car deserves a new one.
    I'm not planning much farther ahead than that, but I'm sure I will end up spending way more money on this car than I should =P.
    Hayward,Ca
    312
    Very nice celica man. yeah 400k is pushing for the engine. id go with a 20r/22r hybrid with dual sidedraft carbs or a 22re/22rte if you want fuel injected :tu:
    May 2010
    California
    59
    Thanks man! Yeah I'm not really sure what to put in there, I know that parts for 22r's are probably more abundant than 20r's. what would be the upside to a 20r/22r combo? and which block gets used (I'm assuming 22r block and 20r head to make higher compression?)
    Hayward,Ca
    312
    Quote Originally Posted by adamyee
    you are correct you use the early 22r block with a 20r head because the 20r head flows better than 22r head design. alot of 20r and 22r parts are interchangeable. you should join the 1stgencelica.com forum. its a great site for these old celica. im on there as well. i have a 73 RA21 celica with a 22re
    May 2010
    California
    59
    pretty cool , what did u do about that funky trap door style mass air flow sensor?
  1. 1975 RA22 Celica Restoration - The75Celica.com
    By BoostMe in forum Toyota Garage
    Last Post: 11-20-2014, 09:53 AM
  2. next project
    By sweave65 in forum Toyota Garage
    Last Post: 07-01-2014, 07:59 AM
  3. RA22 in Dallas, TX
    By 5spd in forum Introduce Yourself
    Last Post: 02-12-2014, 11:10 PM
  4. f/s momo hub for ra21,ra22 ,ta22
    By oneta22 in forum Toyota Swap Meet
    Last Post: 10-08-2010, 05:10 AM
  5. project rusty!! my new gto project !! new member!
    By j.c grime in forum Mitsubishi Garage
    Last Post: 01-07-2010, 08:52 AM
