Results 1 to 6 of 6
Thread: help with 2.0l MA engine timing
    Feb 2009
    NORWAY
    27
    i resently changed out the 4speed 1.8l MA engine setup in my 78 929 wagon to a 5speed 2liter MA engine setup from an 82 929hb.
    i did this in the belief that it would get me some ekstra power, and lower my cruise rpm. the rpm got alot better, buuuuut. the engine is seriously low on power. its not as powerful as the old engine, and it struggles on hillclimbs.
    i know the timing is fucked upp, and i have tried to fix it. but whatever i do, it doesnt seme to get more power.
    how are you suposed to set the timing? (i have a timing light gun)
    whitch sylinder do i get the read from? what rpm do i adjust from.
    what i have done so far is adjust on low idle, with signal from the front sylinder. i have set it to the little point marked before the top dead senter mark on the crank pulley.
    am i doing something wrong?
    Mar 2009
    netherlands
    79
    You have to adjust from the first cillinder. In 99% its the one closest to the radiator. The engine must be at operation teperature and running at idle speed.
    Probably you have 2 marks on the crankshaft pully. 1 is the TDC mark the other other one is your advance timing mark( left one seen from the front).
    Apr 2010
    belgium
    24
    As far as i can tell, you're following the correct procedure, assuming your crank pulley is on the right way. Point the needle to TDC on compression stroke and see where the rotor arm in the dizzy is pointing. Should be about 10-11 o' clock
    Did you remove al the auxilaries and anti pollution crap these "recent" MA engines had? They were seriously strangled in the 80ties. How is it on compression? What carb is on there?
    Feb 2009
    NORWAY
    27
    well, i blew a hole in the rear cylinder a couple of months ago. so now im done with piston engines,i hate them.
    the car has been dismanteled for painting and some restoration.
    beside the car lays a cute little 12a thats going in after paint.
    cant wait to get some daily rotary in my life again (the FD is in 3year storage)
    Feb 2009
    NORWAY
    27
    Feb 2009
    NORWAY
    27
    Quote Originally Posted by Sexy Hammer
    so, how is the 12a going to enhance your low-end performance, specifically in a hillclimb scenario?
    well, with a good exhaust system and msd ignition i will be at 150hk( at least thats what my tuner told me)'
    thats twice the power of the pistoncrap, as far as my experience goes, low end wont be a problem. the 929wagon isnt that heavy
  1. 22R Cam timing
    By ill-minded in forum Toyota Garage
    Last Post: 11-06-2013, 01:10 PM
  2. 4M timing cover...
    By Wagon_MX29 in forum Toyota Garage
    Last Post: 08-15-2012, 02:44 AM
  3. need help adjusting my timing
    By jamesandoval in forum Datsun/Nissan Garage
    Last Post: 09-01-2011, 10:18 PM
  4. setting static timing on a L16??
    By patra_is_here in forum Datsun/Nissan Garage
    Last Post: 02-27-2011, 07:04 AM
  5. Timing kit datsun 510
    By Miguel SSS in forum Datsun/Nissan Garage
    Last Post: 11-09-2010, 08:11 PM
