Results 1 to 8 of 8
Thread: new guy, 81 corolla wtf did i just do?
    May 2010
    Colorado
    19
    so i got an 1981 corolla that i really didn't need but wanted.
    2 door
    got the 1.8l 3tc?
    any ways i am completely new to classic jap cars and these.
    i love mazda's and rotaries.
    i also love simple and basic cars, hence the 81.
    but i could use some education on what i got myself into.
    so any info and aftermarket support links would be greatly appreciated.
    and now the ?'s
    how reliable is this engine.
    is there a fuel injected version or easy swap?
    cheap upgrades?
    May 2010
    Colorado
    19
    no help?
    also what is the curb weight on these?
    they seem so light they could be blown away.
    its great!
    Apr 2009
    Grove,Ok
    23
    Curb weight is just a tad heavier than you might think but not unbearable. My last 81 was a coupe and at the grain silo scales it weighed 1964 lbs. The 3tc is pretty reliable but are prone (at least ime) to oiling issues. Blueprinting the oilpump during a rebuild is a must. They will make nice power pretty easily and aftermarket support is pretty good still.
    FI is expensive and imo only worth it if you are going turbo.
    May 2010
    Colorado
    19
    Quote Originally Posted by rudejester510
    what do you mean blueprinting the oil pump?
    i just wonder about because i live in denver and drive around a lot and change altitude a lot.
    so would fi be better suited for that?
    or can a carb handle it fine?
    i know nothing of carbs really.
    and now pics.
    Jun 2008
    Portland, OR, USA
    452
    Well for carbs wise you will do just fine in Denver. If you have a high altitude kit installed on your car then there shouldn't be any issues, otherwise if anything I forget the town south of there my dad used to go to when we lived in Denver, but he would drive down there to adjust the carb by using a vac gauge.
    May 2010
    Colorado
    19
    Quote Originally Posted by bajasoobnut
    Well for carbs wise you will do just fine in Denver. If you have a high altitude kit installed on your car then there shouldn't be any issues, otherwise if anything I forget the town south of there my dad used to go to when we lived in Denver, but he would drive down there to adjust the carbh by using a vac gauge.
    how do I tell if it has a high altitude kit on it or not?
    Jun 2008
    Portland, OR, USA
    452
    there should be a sticker or tag under the hood that will point it out, it will prolly be part of the vacuum line diagram
    May 2010
    Colorado
    19
    ok i'll have to check it out when i get some time.
    thanks a lot for the info.
  1. 76 Mango Corolla tail lights and trim and 79 Corolla Grill
    By c_copperpot in forum Toyota Swap Meet
    Last Post: 12-05-2012, 03:04 PM
  2. Corolla AE90 Sedan & Corolla Sprinter
    By Daddy Toyota in forum Toyota Garage
    Last Post: 06-14-2012, 07:10 PM
