Results 1 to 10 of 11
Thread: transplant
    Apr 2010
    philippines
    134
    transplant
    good day toyota experts, i'm researching for a possible project, i just want to ask, will the rear wheel drive 1S transmission fit a 2nd gen front wheel drive 3S-GE?
    Sep 2008
    Boston, Assachusetts
    900
    Re: transplant
    Quote Originally Posted by motorhedz01
    Isn't the FWD 3S-GE a transverse mounted engine? So if the 1S is a longitudinal tranny, that should be an odd fit, right? It may take some customization. :|
    Apr 2010
    philippines
    134
    yep, i'm thinking since both of them are the same s series engine, do they have the same transmission bolt pattern on its block?
    Apr 2010
    snohomish, washington
    497
    I have heard of doin that but I never saw it done soooo. Try it out and tell use if its possible. And remember anything is possible if you got money.
    Nov 2009
    Shiki-Shi, Saitama Japan
    78
    i think you can use it as long as you use the bellhousing from the 3sge toyota altezza
    Philippines
    75
    Saves you from the headache of fabrications and hassle in installation.
    Apr 2010
    philippines
    134
    yep, if he had the budget we'll definitely go with the altezza motor, sadly we dont, we'll just go with whats currently available to the budget, heres the story, this friend of mine is looking for a project car and he spotted a third gen celica thats been stock in a garage for years, it has a stock carburated 1s motor, he told me what possible better motor could fit in it, i said maybe some other late model s series motor could fit, i told him i had a 2nd gen fwd 3sge lying around in the shop, maybe that would fit but i'm not sure, so before he acquire the car, we just want to be sure if its possible to make the conversion with as little as what we have, it would totally save us some time and money experimenting, and so here we are asking
    Nov 2009
    78
    actually, since it has s engine mounts and bellhousing, it should fit in fairly well unless there is a huge difference between the 1s and 3s engines
    5,529
    So would keeping the original engine. :P
    Mar 2009
    nelson,NZ
    11
    shure it can be done plenty of info if you look in the rite place .http://www.club-k.co.nz/Forums/today.php have a look here there are a few people over here that have done 3sgte gen2 conversions into starlets ect things like using the 1s oil pick up and sump im prety shure you can use the 1s bell to .you have to pay to get full membership to acess all the info on that site so hit me up if you cant find what you need
