Results 1 to 10 of 13
Thread: msd6a?
    Apr 2010
    vancouver island
    52
    msd6a?
    hi i know i ask alot of questions but you guys seem to have lots of answers and i greatly appreciate the help i find on this forum
    now for my question
    does msd6a replace the stock ignition module (ignitor) or do you still need it. the reason i ask is ive seen some photos floating around the net with 3tc's w/ msd6a and i couldnt see the ignitor anywhere. i found mine and the wiring is mangled, and i was debating msd6a. what to do now :S
    Feb 2009
    Northridge, CA
    169
    I have never been able to use the VR pickup AC voltage output from a pre-1985, non-computer controlled timing distributor to trigger an MSD box directly. The signal is not strong enough and needs something to convert it, either the stock ignitor or a GM HEI module.
    Apr 2010
    vancouver island
    52
    so i will need to retain my ignitor then? all of this information is new to me. this is the 1st car ive ever built.. or attempted to build
    Feb 2009
    Northridge, CA
    169
    Yes.
    5,529
    Quote Originally Posted by BigSteve
    FWIW, there are lots of Datsun guys ditching their ignitor when running a 6A/6AL. Not sure what Nissan did different but no one has reported any ill effects from it? In fact, you're the first person I've heard of that did have a problem with it? Kooky...
    But since I haven't personally done it, I'm inclined to agree with keeping it. :tu: :mrgreen:
    Feb 2009
    Northridge, CA
    169
    I've done it for years with L28 distributors...just dump the black box on the side of the distributor and hook the leads directly to the mag pickup wires on the MSD box. Works like a charm!
    However, the Toyota signal output is quite weak and won't trigger the box directly...at least with the 18R-G, 20R, and 22R/RE distributors I've tried it with.
    Apr 2009
    Central Fl
    196
    I have had it on my 22r no problems but u got to use a 12v coil always worked fine no problems same on both my 1.8s
    5,529
    I've done it for years with L28 distributors... However, the Toyota signal output is quite weak and won't trigger the box directly...
    Well that explains it. Thanks. :mrgreen:
    Jan 2009
    Mauka
    66
    I have run the MSD on many 3TC's all without the ignitor. Most set ups I have seen on the 3TC have ditched the ignitor.
    Apr 2010
    vancouver island
    52
    Quote Originally Posted by 73te27
    any chance you can explain/simplify how to do so for me?
