Results 1 to 10 of 10
Thread: te72 steering
    Apr 2010
    vancouver island
    52
    te72 steering
    i have a steering box in my car and was thinking of converting it to an ae86 manual rack. does anyone know what i need to do to make this a functional conversion
    "i had planned on buying the battle version kit 1 and 2 but then realized its not for my steering setup" those unfamiliar the battle version extends steering ability thus creating better drift angles
    5,527
    Easiest way would be to find an '83 in the junkyard. It shares most of the AE86 front end bits and should bolt right into your car. :tu:
    Apr 2010
    vancouver island
    52
    83 is an ae86 right? or is that the ae71?
    they seem to crush to many cars where im from so 86's are more common
    AE71 is 83
    fontana, CA
    173
    ok, you will need to do this. get the cross member from an ae71, steering column, and control arms as well. now, from what i was told before. you will have to cut the engine mount brackets that are on the cross member from the te72 and put them on the ae71 cross member.
    Apr 2010
    vancouver island
    52
    ive found ae71 setup but was told that the bar that goes to the rack will interfere with the header..
    can anyone comment on this?
    If you use the AE71 cross member, Steering column, intermediate shaft, and rack and pinion you will have to modify the exhaust manifold of a 3tc. If it was a A series motor like a 4ac or 4ag you would have been fine.
    Apr 2010
    vancouver island
    52
    i see well i dont want to change to an "a" engine, and im not about to hack up a brand new header :S i guess stock steering it is.
    is there anyway to increase the steering radius on te72 stock setups?
    Ive heard that the TE72 gets the same amount of angle as a AE86 with a manual rack, I would really like to clarify this for sure. Do you have a TE72 with power steering?
    Apr 2010
    vancouver island
    52
    negative on the power steering just good ol armstrong gear box
  1. Te72 wagon steering issue
    By Hollywoodae86 in forum Toyota Garage
    Last Post: 04-09-2015, 03:55 AM
  2. FS: te72 80-83 steering wheel oem black
    By goofesgts in forum Toyota Swap Meet
    Last Post: 03-03-2013, 02:09 PM
  3. Tilt steering ideas for TE72 Corolla
    By in forum Toyota Garage
    Last Post: 08-04-2012, 04:13 AM
  4. ae86 steering hub on te72??
    By benny_b in forum Toyota Garage
    Last Post: 05-10-2012, 11:10 PM
  5. OBA Steering wheel
    By matsuda9 in forum Resto Tips, Wheels & Other Goodies
    Last Post: 09-27-2010, 05:48 PM
