Results 1 to 6 of 6
Thread: B R?
    Feb 2010
    st louis mo
    45
    B R?
    im looking to drop my 81 celica gt but i have not found aftermarket springs
    so i was wondering if someone could give me some ideas
    thanks.
    Mar 2010
    Chicago
    163
    No experience with it personally, but my Corona was dropped by a previous owner. I was told they heated the springs to do it...
    Feb 2009
    Northridge, CA
    169
    Pedders and Lovells both make them. Whiteline has a strut tower bar and swaybars for your car, as well.
    Feb 2010
    st louis mo
    45
    Quote Originally Posted by BigSteve
    well ive googled both brands and i cant find anything for a celica do you have a direct link?
    thanks
    belgium
    112
    with coilovers ath the front and spring's from a toyota yaris at the back.
    Shot at 2010-02-26
    Shot at 2009-05-19
    and here with the same wheels as your's.
    Shot at 2009-07-19
    Feb 2009
    Northridge, CA
    169
    Lovells, Page 16
    http://www.lovells.com.au/catalogue/...2009-09-03.pdf
    Pedders
    http://www.pedders.com.au/catalogue
    Toyota
    Celica
    1977-1981 RA40, TA40
    Front Shocks
    8728 8728 Comfort Gas Cartridge
    9728 GSR9728 GSR Cartridge
    Front Shock Mounts
    5875 5875 Toyota Strut Mount
    Front Spring Low
    2053 2053 Sports Ryder Coil Spring
    Front Bump Stop/Kit
    4359 4359 Bump Stop & Boot Kit
    Front Sway Bar Links & Bushes
    EP755 Urethane Shock Bush
    EP3320/21 Urethane SwayBar_D Bush
    EP3320/23 Urethane SwayBar_D Bush
    Lower Ball Joint
    PBJ145 Pedders Ball Joint
    Outer Tie Rod End
    PTE489L Pedders Tie_Rod End
    Inner Tie Rod End
    PTE490R Pedders Tie_Rod End
    Idler Arm &/or Bush Kit
    PSX1141 Pedders Idler Arm
    P5824 P5824 Idler Bush Kit(Pkt2)
    EP2076 Urethane Steering Pivot_Idler
    Pitman Arm
    PSX5241 Pedders Pitman Arm
    Radius Rod Bush
    EP1307 Urethane Radius_Rod Bush
    5844 5844 Pedders Rubber Bush(Pkt4)
    Lower Inner Bush
    5830 5830 Pedders Rubber Bush(Pkt2)
    EP6087 Urethane Control_Arm Bush
    Rear Shock
    3356 3356 Touring Black Gas Shock
    8056 8056 Comfort Gas Shock
    9067 GSR9067 Gas Sports Ryder
    EP148 Urethane Shock Bush
    EP198 Urethane Swaybar_Link Bush
    Rear Spring Low
    2054 2054 Sports Ryder Coil Spring
    Rear Spring Standard
    7054 7054 Heavy Duty Coil Spring
    Rear Airbag
    NOTES Special Information
    Rear Sway BarLinks & Bushes
    EP280 Urethane Swaybar_Link Bush
    EP4010 Urethane Swaybar_Link Bush
    EP3364 Urethane Swaybar_Link Bush
    EP3320/14 Urethane SwayBar_D Bush
    Rear Trailing Arm Lower
    5842 5842 Pedders Rubber Bush(Pkt4)
    EP1018 Urethane Control_Arm Bush
    Rear Trailing Arm Upper
    Rear Panhard Rod / Watts Link Bushes
    EP427 Urethane Panhard_Rod Bush
    EP963 Urethane Panhard_Rod Bush
