Results 1 to 10 of 17
Thread: Head Unit wiring help
    Jun 2008
    Australia
    198
    Hey, I'm currently trying to hook up a modern head unit (93 camry) to my corona, there's a bit of wiring involved to get it to work properly.
    The original corona radio plugs are a 3 pin(speakers I assume) and a 2 pin(gnd and acc(12v)).
    My query is: does the new h/u need acc AND batt(+) AND gnd to operate, or can I just use batt AND gnd?
    Any help appreciated
    -Long
    Dec 2007
    New Zealand
    210
    No you need all three, otherwise with just battery and Gnd it will be power on even when you take the key out, and can drain your battery if you accidentally leave it on.
    With just Acc and Gnd and you will loose presets once ignitions turned off.
    Jun 2008
    Australia
    198
    Quote Originally Posted by RedSunday
    Thanks Redsunday,
    At the moment I'm taking +ve from the lighter (can't remember if the lighter was acc or batt now) I'm assuming it was acc, do you know a good place to take batt(+) from? Or should I just run a line right to the battery?
    Aug 2009
    Los Angeles, CA
    182
    just run it straight from your fuse block but just add another fuse.. or is the Sig lighter is 12v constant (12v+ Bat) you can run it from her since the cig lighter is fused.. as for the acc 12+v you can just run it straight from the ignition switch...
    Jun 2008
    Australia
    198
    Quote Originally Posted by arsonist63086
    Yes, the cig lighter is fused so I'm running 12v const from that, How do I run the 12V acc from the ignition? any pictures and such? I'm a noob at this.
    Also, by taking it from the ignition switch, does it affect anything? (ie. current division)
    Jun 2008
    Australia
    198
    Ok,
    Final piece of the puzzle is finding the best spot to connect 12V acc to.
    I ran 12V acc from the +ve connection of the radio fuse but the head unit seems to be pulsing which is wierd (all the interior lights pulse on aswell).
    Can someone tell me how to wire up acc properly? Any help appreciated :tu:
    Aug 2009
    Los Angeles, CA
    182
    Ok the pulsing aunt good.. You can use the ACC 12v but you need to unplug the original head unit, also it would be best for you to run a new ground to the frame and not from the original wireing. Ps. If you get engine whine you can install a filter on the 12v batt side or just run a wire straight from the batt... Hope it helps
    Jun 2008
    Australia
    198
    Hey Arsonist,
    Yes, I have unplugged the original unit, I've also tried a different grounding point and also a direct line to the battery, but I still get the weird pulsing
    Jun 2008
    Australia
    198
    Wires I have:
    Alternative GND point:
    Where I've taken ACC:
    Boots up with wierd pulsing, still no sound yet with speakers and antenna plugged in
    Aug 2009
    Los Angeles, CA
    182
    Oh ok hmm... Have you tested the new head unit straight at the bat. (benched tested the unit) before installing it. If it still pulses when bench testing it the unit I bad. Also try grounding the units metal shell to ground (just to make sure you have the right ground wire from the plug), onother thing you can't use the commen ground setup most old units use (meaning 1 neg. Is shared between 2 speakers) so you will have to run new quering to all the speakers. If your using the comeb ground set up with the new unit it will cause the pulsing thing you have going on. Hope this helps you out...
  1. WANTED: Zenki TE71 GT wiring diagram - Instrument Wiring
    By oldeskewltoy in forum Toyota Garage
    Last Post: 09-20-2014, 02:57 PM
  2. rwd 4g32b head vs a 4g37 head, also turbocharging the lancer
    Last Post: 07-06-2013, 03:26 PM
  3. RA 29 fuel sending unit
    By lcmartin46 in forum Toyota Garage
    Last Post: 11-18-2011, 11:58 PM
  4. 1600 sending unit
    By MikeRL411 in forum Datsun/Nissan Garage
    Last Post: 01-31-2011, 10:44 PM
  5. Air Conditioning Under Dash Unit
    By Norcal510 in forum General Discussion, JNC News & FAQ
    Last Post: 09-28-2010, 05:41 AM
