Results 1 to 2 of 2
Thread: Oil Catch Tank??
    Apr 2009
    Central Fl
    196
    Oil Catch Tank??
    Alright i just put on my Cannon intake on my 20r, Vefore i was using a stock intake and i was running a catch can from the back nipple on the valve cover to the tank and the other hose went to where the egr diaphram or what ever on the intake. No oil leaks or nothing Well now i cant use the nipple on the intake cause there is no provisions for emissions on the Cannon which is fine but now i have oil soweing on my valve cover and the front filter soaked in oil. Now my question is
    Should i hook up a catch cam from the pcv valve and put a nipple on the intake and run it like that?
    Or should i just hook the 2 fittings on the valve cover to a tank
    I dont think putting 2 filters is going to fix the problem
    Apr 2010
    snohomish, washington
    497
    What will it hurt if you run it nothing. I'm goin to be running one on my 2tc and one of my 20r when I get it built. Just get rid of the pcv valve all together the catch can basically works as one.
  1. Gas Tank Restoration
    By Camshaft in forum Resto Tips, Wheels & Other Goodies
    Last Post: 02-23-2012, 04:16 AM
  2. Gas tank info
    By sfbmx88 in forum Toyota Garage
    Last Post: 12-04-2010, 12:33 AM
  3. Gas tank questions
    By yellow_sub in forum Toyota Garage
    Last Post: 10-18-2010, 08:00 PM
  4. Best Way to Catch Oil & Fluids
    By ben in forum Resto Tips, Wheels & Other Goodies
    Last Post: 06-21-2010, 07:29 PM
  5. TV Show "Catch It Keep It"
    By john in forum General Discussion, JNC News & FAQ
    Last Post: 09-02-2009, 04:12 AM
