Results 1 to 5 of 5
Thread: T series engine question for toyota people
    Apr 2009
    Christchurch, New Zealand
    83
    I'm a Datsun fan but I've become quite fond of my automatic 3tc tt132 corona
    but its getting quite tired and I'm thinking of modernizing it.
    I've got some questions about the t series engines i wondered if someone could answer some questions for me?
    are the manifolds on 2tg and 3tgte's compatible?
    and can you use 2tg pistons in 3tgte's?
    I've been thinking i would like to source a 3tge, put some after market high compression pistons for a 2tg in it, and run it naturally aspirated.
    could i use the intake manifold and extractors from a 2tg?
    I'm not looking for an overly powerful engine. just something that will suit it and run nicely.
    do you think it would be worth sorting out a 3tc crank to increase the displacement?
    I'm thinking yes.
    i already have most manual conversion parts and i know of and am enquiring about a w50 gearbox and a 3tgte long block.
    thats about it.
    cheers
    Jul 2009
    New South Fails, Australia
    225
    My cousin's old TT104 (originally RT104) had a 3TG. Pretty sure it was a 3TGTE long motor rebuilt using 3TC pistons, custom cams and dual 40mm Solex's off a 2TG.
    There's also a few 3TC/2TG hybrids getting around, using a 2TG head on a 3TC block.
    Jan 2008
    so cal
    100
    Re: T series engine question for toyota people
    intake NO exhaust YES
    different pin height NO
    2TG head is better than 3TGTE, normally aspirated
    NO
    YES
    do you think it would be worth sorting out a 3tc crank to increase the displacement? I'm thinking yes.
    for a 2TG YES
    Nov 2009
    Newcastle, Australia
    6
    I remember something way back about a 3Y crank will drop in a 2T block (albeit with a bit of meat carved out) to stroke it out to two litres.
    The downside being the 3Y crank is cast while a 2T-G is forged.
    Anyone else confirm this?
    Jan 2008
    so cal
    100
    confirmed
  1. Easy question (hopefully) 30 series cedric diff
    By Shamus11 in forum Datsun/Nissan Garage
    Last Post: 07-17-2015, 12:39 PM
  2. Toyota K-Series Lightweight Engine Pulleys
    By redvalkyrie in forum Toyota Swap Meet
    Last Post: 12-17-2014, 10:04 PM
  3. A-series engine swap questions
    Last Post: 10-13-2014, 05:41 PM
  4. ra40 series GT coupe with boot lid, headling question
    By Celica RA45 in forum Toyota Garage
    Last Post: 12-11-2012, 04:17 AM
  5. Toyota Engine Question
    Last Post: 06-22-2009, 06:08 AM
