Results 1 to 3 of 3
Thread: 197X Mazda 929 heater hose routing
    Jun 2009
    Melbourne, Australia
    802
    Here's my problem:
    1974 Mazda 929.
    Water pump has a screw in fitting on top of it.
    the inlet manifold has the same type of fitting screwed into the side facing the firewall.
    at the back of the inlet manifold there is a t-piece fitting that is near the strut tower.
    The side of this T fitting that runs towards the radiator has a hose that goes to the fitting on top of the water pump.
    I just need to know which heater matrix hose goes to what fitting on the inlet manifold. ie does the top heater hose from the matrix go to the T piece or does it go to the screw in fitting?
    Apr 2010
    belgium
    24
    Re: 197X Mazda 929 heater hose routing
    that is correct
    T piece goes to top (where the valve should be on the matrix)
    Jun 2009
    802
    ah ha. thanks for that. I'm pretty sure there is no tap (ie to turn off the coolant flow through the heater core) but I'll have a closer look tomorrow.
    Cheers
    edit: just clued on, one of the controls on the dash open and closes a valve on the top pipe I think.
  1. WTB - 1973 Mazda Rx2 Heater Core
    By Apple Guy in forum Mazda Swap Meet
    Last Post: 01-01-2013, 05:58 PM
  2. Newbie with a N600. Battery Cable routing Q's
    By 1gencrx in forum Honda Garage
    Last Post: 05-23-2011, 04:14 AM
  3. Heater control valve for '78 810
    By Kujira in forum Datsun/Nissan Garage
    Last Post: 12-16-2010, 04:04 AM
  4. 1986 toyota cressida NEED HELP hose connection and such
    By khmerxs13 in forum Toyota Garage
    Last Post: 09-28-2010, 12:55 AM
  5. Fuel Injector Hose Issue...
    By Dachshund in forum Datsun/Nissan Garage
    Last Post: 09-18-2010, 12:42 AM
