Results 1 to 2 of 2
Thread: WTB Rear rotors to suit 1980 zz/r gemini. help needed please
    Jul 2007
    Midwest, USA
    The original Aquarius conversion was Piazza rotors and emergency brake, that bolt right onto the Gemini axle. But there seemed to be an extermination program against Piazzas in Australia, and the remaining 100 or so are fiercely protected by the members of the Australian Piazza owners club.
    The emergency brake rides on the inside of disk and is a mini drum brake, so there are three braking surfaces. Without a Piazza donor, you're looking at very expensive machine work for merely stock performance level.
    You could go the exotic car route with the Brembo disk type emergency brake caliper and do away with the center mini drum brake. Only 1500 USD per pair of those calipers. Whenever people ask why you have two rear brake calipers on each side, you could say the car has the same emergency brake as a Lamborghini, Ferrari, or upper range Lotus.
    Jun 2009
    Queensland, Australia
    yeah i'm pretty sure he wants original replacement discs only, not a conversion, he's resoring to showroom stock...
  1. 1977 sports coupe rear axle ratio options info needed
    By heavyrolla in forum Toyota Garage
    Last Post: 04-15-2015, 05:10 AM
  2. Help! 510 rear bumper needed
    By Bluebird51 in forum General Discussion, JNC News & FAQ
    Last Post: 06-10-2014, 04:22 PM
  3. new rear windscreen rubber to suit ra40 series coupe
    By Celica RA45 in forum Toyota Swap Meet
    Last Post: 07-05-2013, 12:52 AM
  4. 1980 MX32 Rear Springs
    By ManuelMTZ in forum Toyota Garage
    Last Post: 08-29-2012, 02:21 AM
  5. Parts needed for 1980 toyota liftback
    By tech5 in forum Toyota Swap Meet
    Last Post: 04-13-2011, 02:13 AM
