Results 1 to 10 of 18
Thread: B-210 wheel size recommendations
    Jan 2010
    new Orleans, La
    5
    So, my new 78 datsun b210 will be arriving by carrier in Monday, and I'm itching to get started on it. I'll be ordering volk te37s in a 15" size, but im looking for width and offset recommendations. I'm looking to fit flush, but no stretched tires. What do you guys suggest? Pics coming on Monday!
    5,527
    With stock brakes and say a 15x7 (you didn't mention width, which is key to offset and fitment), I would suggest a +15 to +20 on the front and a zero offset to +10 on the rear. :tu:
    If you want flush without stretched tires, a 7" is all you can fit in the front. It's fairly simple to squeeze an 8" in the rear, if need be.
    5,527
    Also, keep in mind you will have to roll the rear fender lips. :tu:
    Jan 2010
    new Orleans, La
    5
    Cool beans. Yeah I was thinking a7-8 width but as this will be my first datsun I was unsure since it isn't here yet. That's exactly the info I was looking for. Thanks!
    Mar 2007
    Tasmania, Australia
    219
    15s are miles too big, its going to look donk.
    5,527
    Quote Originally Posted by 1eightySX
    What if one were to look into overfenders and had no issue with a stretch?
    Then I'd say the sky is the limit. 8)
    With decent sized flares/overfenders and a goodly stretch I'd say an 8-9" wide wheel in a zero offset to -20 isn't out of the question.
    I was thinking 13 or 14's in a width 0f 7 to 8. Just unsure of what type of offset to run,
    Depends on how wide those overfenders/flares are. :wink:
    If you're not running flares, a 14x7 -10 is just about the limit with a decent stretch (175/65-14).
    5,527
    Quote Originally Posted by seventhskyline
    FWIW, here in the states it's getting really tough to find good quality tires for 13" and 14" wheels. :x
    A 195/50-15 is still available in a wide variety of compounds/trad patterns, so...
    Mar 2007
    Tasmania, Australia
    219
    195/50R15 is a wagon wheel compared to what it came with man.
    185/60R13s are pretty common, 185/60R14s are common....should be no issue getting rubber.
    5,527
    Its the exact same diameter as stock... :P
    Not here in the US. Almost impossible to get these days.
    Getting rubber? No, super easy. Getting good rubber? Not too easy in that size...
    185/60-14 is still a common enough size that getting all season tires in that size is easy. But any performance tires in that size have been all but phased out by all the tire companies here. :x
    Dallas TX
    69
    15s are definitely not donk on a b210.. I had 14s on mine and it looked fine.. it could easily have had more.. 14x7 -9? konig rewinds
    280zx front suspension. stock rear
    stock ride height.. wheels look tiny
    all the way down
  1. Volk Wheel Size?
    Last Post: 12-22-2014, 06:10 PM
  2. DR30 Wheel size and offset help
    By Davboy in forum Datsun/Nissan Garage
    Last Post: 07-12-2012, 07:17 PM
  3. C10 with MK63 calipers - min wheel size?
    By ericbauer in forum Datsun/Nissan Garage
    Last Post: 03-26-2012, 06:06 AM
  4. Mazda 616/Capella steering wheel hub size
    By BlueRocket in forum Mazda Garage
    Last Post: 07-17-2011, 03:30 PM
  5. wheel size and gear calculator
    By arsonist63086 in forum Resto Tips, Wheels & Other Goodies
    Last Post: 12-10-2009, 05:29 AM
