Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 1982 SAPPORO with pics
    Mar 2010
    los angeles
    24
    1982 sapporo 2.6 I4 Automatic. Here some pics
    5,530
    Looks very clean from the photos. :tu:
    Did you just get it?
    Mar 2010
    los angeles
    24
    1982 sapporo
    Yes just got it month ago it was a dealer trade in
    Dec 2009
    Newcastle/ Australia
    135
    Yep, pretty tidy :tu:
    What are your plans for it?
    You might want to have a look at sigma-galant.com, there are a few of these models on there that members have done up. It's an Australian based site so they are mainly known as Scorpions, but some are Sapparos as there are international members too.
    Mar 2010
    los angeles
    24
    im thinking of restoring and getting some rims for it
    Feb 2010
    Cleveland, Ohio
    1,608
    Nice car, love the Galant Lambdas!
    Feb 2010
    Russia
    1
    nice car)
    very brutal 8)
    Nov 2008
    santa rosa. Ca.
    128
    Niiice O.G. Sapporo! have you got any mods planned?
    Mar 2010
    los angeles
    24
    I wanna drop it but have no idea where to start.and i wanna get the missing center console replace
    Nov 2008
    santa rosa. Ca.
    128
    planning to lower it! I was hoping you would say that (cause i didn't want to say how DAMN badly it needs it!)
    there's a right way and a wrong way to do just about anything... the lowering of a sapporo, as I have recently found out, is not necessarily so. if your shocks and struts ARE NOT completely blown, you may be able to modify the bump stops (cut them down) and cut down your coil springs. I was very surprised at how well my car rode with two coils cut front and rear! (the rears are progressive, with different thickness coils top to bottom, you want to cut the thicker side) this is NOT the recommended method of lowering a vehicle. it usually results in a bumpy harsh ride. (but then again, this type of drop usually results in prematurly wearing out your shocks/struts anyways!) Remember, you MUST cut down the bump stops. I also avoided opening the brake system hydraulics by cutting a notch in the bracket that holds the two soft lines together on the strut, and slipping the line out the back! (re-install the retaining clip vertically thereafter) use the proper McPherson coil-spring compressor tool to remove the front springs, and the rears drop out one at a time by removing the shock and prying the axle away from the spring at the perch.
    with the two coils cut, the car should sit close to 2 inches lower, and seems to have a pretty flat ride (check my recent pics)
    the RIGHT way to lower the thing, is to run a short stroke strut and shock setup, and custom made shorter/higher rate springs, or go to fully adjustable coilovers front and rear. I'm planning on making a set at some point, probably using 'Ground control" parts, and tokico illumina inserts for the MR2. (and progressive rate bump stops!)
    good luck! hope my rambling is of help! :tu:
  1. 1982 Mitsubishi Sapporo 2000
    By wkopczyk in forum Mitsubishi Garage
    Last Post: 06-27-2013, 10:04 PM
  2. 1982 Plymouth Sapporo on Baltimore Craigslist
    By bgt01 in forum Ad / Auction Finds
    Last Post: 11-28-2012, 06:21 PM
  3. My Sapporo
    By in forum Mitsubishi Garage
    Last Post: 09-20-2009, 08:21 PM
  4. My Sapporo
    Last Post: 07-27-2009, 10:00 PM
  5. 2009 toyofest pics warning lots of pics and a funny ass vid!
    By dominicaneddy in forum Events, Meets & Gatherings
    Last Post: 05-23-2009, 09:54 PM
