Results 1 to 4 of 4
Thread: oxygen sensor for air/fuel ratio
    Jul 2008
    Quezon City, Philippines
    22
    has anyone installed an oxygen sensor for their carburetor type engines? i searched the net for this. it says it'll aid me in tuning my carb.
    Jun 2008
    The Hills, OR
    248
    Get a wideband system:
    AEM Uego
    Innovate LC-1(with gauge)
    These types of oxygen sensors are able to output a wider range (resolution) / more precise measurements of the air/fuel ratio. Most stock sensors are called narrow bands, as they only output rich or lean of 14.7:1 (stochiometric optimal gasoline to air ratio), while still helpful... a wideband is a much better tuning tool.
    -Robert
    Feb 2008
    East Wallyworld Vermont USA
    99
    I use a Techedge wideband in mine. Very handy and makes quick work of setting up a carb.
    You can see the TE unit in the lower right corner near the firewall.
    I do not have any pics of the display.
    Jul 2008
    22
    thanks guys!
    it seems that both are way off my budget... do you know a setup that's more from the ghetto.
  1. ***OH 2 Sensor 7MGE?**
    Last Post: 05-06-2015, 09:41 PM
  2. 1977 sports coupe rear axle ratio options info needed
    By heavyrolla in forum Toyota Garage
    Last Post: 04-15-2015, 04:10 AM
  3. Where can you buy a fuel pump and fuel tank for 1988 galant?
  4. Fuel filling issue from Gas station fuel nozzles
    By RT119Patrick in forum Toyota Garage
    Last Post: 02-14-2014, 05:13 AM
  5. Diff ratio?
    By Toyohead in forum Toyota Garage
    Last Post: 07-21-2012, 07:43 AM
