Results 1 to 10 of 13
Thread: Quick Colt engine question
    Aug 2008
    Dallas, TX
    11
    Is there significant differences between a 4G32 (1.6) and a G32B (1.6 engine? In particular years from 1979-1984/ Non turbo. These were in both the front wheel drive and the rear wheel drive Colts/Champs.
    I'm looking for rebuild parts and I find mostly G32B stuff, but it all appears to be the same as the 4G32. I'm confused.
    Thanks, Todd
    Feb 2008
    scappoose, or
    754
    There might be a cylinder head difference. I'm not sure what year they changed the water port on the intake side of the head. I have something like a 1986 colt turbo intake and the water port on it is MUCH larger than the 78 lancer belt driven head I have. THey wont interchange unless oyu build some kind of sandwich plate to block the water port portion that is
    Here are some slight differences in the 78 year heads. Nothing drastic, but there are a few small changes.
    http://classiccolt.forumcircle.com/viewtopic.php?t=622
    Here is your differences from the early belt driven heads to the later heads that were on the turbo models and then also the 4g37 engine. I took a lot of pictures so you can get an idea.
    http://classiccolt.forumcircle.com/viewtopic.php?t=536
    Feb 2008
    East Wallyworld Vermont USA
    99
    The 4G32 has a chain driven camshaft with the distributor in the timing case.
    The 4G32B has a belt driven camshaft with the dizzy mounted in the head.
    The 4G32 was RWD only and used by Mitsubishi till 76-77 depending on the country delivered to. Hyundai continued use of the chain driven engine till the late 80s.
    The 4G32B was available in both RWD, FWD and FWD turbo versions.
    Pistons rods and bearings interchange between chain and belt versions, not much else.
    Aug 2008
    Dallas, TX
    11
    Oh it gets more confusing! LOL
    Where would I be able to get one of those blanking plates to block the fuel pump opening? Also, why are oil pumps so hard to locate for these engines?
    Thanks for he info.
    Please excuse this Subi person. I'm Mitsubishi dumb, but learning!
    (I thought the Hyundai was a 1.5 with a belt driven cam in the 80s.)
    Feb 2008
    99
    The Starion has a factory fuel pump blockoff as well as a few other models. Otherwise you make one or have one made for you.
    The oil pumps rarely go bad on them but they are on the market. I have not looked about for on from a belty.
    The Hyundai I refer to is the Pony which was a RWD car that was not in the USA market.
    Feb 2008
    scappoose, or
    754
    Actually the starion block off will ont work on the g32b. It uses a 3 bolt pump in a weird shape instead of the 2 bolt.
    You can get a block off plate off a 4g37 eclipse engine though.
    Here is a pic. g32b from a 1978 up top and the 4g37 eclipse head on the bottom. Notice the block off plate for the fuel pump.
    Feb 2008
    99
    Ahh good correction Shaun, I was thinking G32 since they have the 2bolt style.
    Feb 2008
    scappoose, or
    754
    yeah, I was pretty confused when I was trying to find a replacement fuel pump. The parts stores were getting me the 2 bolt ones.
    Aug 2008
    Dallas, TX
    11
    I really appreciate your help, advice and pics! I'm a true vintage Subaru enthusiast and know those cars inside and out. Alot of that knowledge applies with this Colt, but not all as I am finding out!
    I had a 1980 Colt RS back in the day and I loved it. It was the 1st "non Subaru" I had. I drove that car everywhere and ended up trading it for another Subaru for some strange reason. I should have kept it!
    Last year I found nearly the same car, (not an RS), but a Colt Custom. Same 1.6, twin stick, FWD and same interior as my old car. I set about to restore it. Parts have been a challenge, but I have been able to find and even stockpile many needed items. It's a really sweet stock, unmolested car.
    Of course, all the insider knowledge on Mitsubishi, I am missing...(unlike the Subarus). At any rate, I love this Colt and it looks just fine with all of Subys!
    Has anyone ever used the Jet valve eliminator Bolts?
    http://www.silver-seal.com/product/6..._campaign=6645
    My engine uses the same jet valves.
    I 'm not sure what to think about the jet valves. (MCA-Jet)
    I'll post pics soon.
    Best, Todd
    [/img]
    Feb 2008
    99
    Those first FWD Colt were fun little cars. I spent some time with an 84 turbo version. Great in the hills with the torque and twin sticks.
    I myself just play with the RWD cars, well other than my AWD turbo conversions.
    That bolt set for eliminating the jets is no better than just swapping exhaust rockers to the intake side and leaving the valves in. You are best to get the steel jet cup out of the combustion chamber. This is either done by welding them closed, Big PIA. I prefer to do a cold repair by having aluminum plugs machined that press in and have an 8mm bolt retain them from the top. I machine the plug so there is enough material to blend flush in the chamber.
  1. engine question..
    Last Post: 03-23-2013, 05:42 AM
  2. 3k engine question
    By parrot in forum Toyota Garage
    Last Post: 06-19-2012, 03:42 AM
  3. Quick TE72 Question...
    By TEhDrifter in forum Toyota Garage
    Last Post: 09-30-2011, 06:06 AM
  4. quick question on hr31 skyline
    By astrolux in forum Datsun/Nissan Garage
    Last Post: 10-01-2010, 07:50 AM
  5. HELP ME!!! 5k engine question
    By hypokp in forum Toyota Garage
    Last Post: 08-26-2009, 10:11 PM
