Results 1 to 3 of 3
Thread: 4G63T Differences between Auto and Manual ??
    Jan 2010
    Looking at doing a 4G63T into my challenger, have to get another tranny from a D50 w/ a narrow block, aside from that however, what are the differences going to be since the car will be a manual transmission, and the donor car is an automatic with the 4G63T in it, are there any crank differences as well ecm and harness vs the manual transmission? Thanks guys.
    Feb 2008
    scappoose, or
    turbo is a 9a instead of a 14b also. I belive there is a minor difference in the harness
    Feb 2008
    East Wallyworld Vermont USA
    The general layout of the auto and manual engines are the same.
    The differences you will find are,
    The manuals came with a TD05-14G turbo, 450cc injectors and a low pressure fuel regulator.
    The autos had a TD04-13B turbo, 390cc injector and higher pressure regulator. Depending on what car you source the engine from the automatic camshafts are milder.
  1. Auto transport
    By zakte72 in forum Toyota Garage
    Last Post: 05-26-2013, 03:36 AM
  2. NA to MA flywheel differences
    By Yetchh in forum Mazda Garage
    Last Post: 08-12-2012, 08:31 PM
  3. '80 Toyota Celica repair manual and '99 Tacoma wiring manual
    By rrabespl in forum Toyota Swap Meet
    Last Post: 10-17-2011, 10:32 PM
  4. Differences between 2T-C and T engines?
    By in forum Toyota Garage
    Last Post: 05-29-2011, 01:43 AM
  5. auto to manual tranny swap
    By ghostking in forum Toyota Garage
    Last Post: 07-15-2010, 04:45 AM
