Results 1 to 8 of 8
Thread: WHAT IS BEST WAY TO COMPRESS TE31-51 BUMPER SHOCKS??
    Feb 2008
    Saratoga N.Y.
    729
    Do you just drill a hole in the shock body?
    5,529
    Re: WHAT IS BEST WAY TO COMPRESS TE31-51 BUMPER SHOCKS??
    Quote Originally Posted by whit
    You can, just don't put your face in front of it when you do. :wink:
    The oil inside is supposed to be under pressure, but I doubt it is after all these years. :tu:
    Oct 2008
    Forty-Fort, PA
    105
    I have '77 rt105 Corona and in my bumper shocks was what looked like plastic snow :shock: Just drill a hole in the base(closest to the bumper) and then hit the stud(car)side with a socket to push in....Just make sure you rivet the shaft afterwards so the bumper cant move...
    YOU WILL LOSE IMPACT CUSIONING! :twisted:
    ----But you prolly knew this :mrgreen:
    Feb 2008
    Saratoga N.Y.
    729
    OK that all sounds about what ive been hearing.So now JUST DO IT!
    Maybe I'll have some snow in mine also?
    5,529
    FWIW, I compressed mine (off the car) in a vise, then tack welded them in the compressed position.
    Feb 2008
    Saratoga N.Y.
    729
    =OK I just did this.All tips were correct.Full compression puts you even to just past the metal filler piece.
    =This is real nice on the rear as the rubber end caps fill in the depressions stamped into the rear quarters.
    =Oh and I had the snow also which probably served the same fuction as an oil filled shock??
    5,529
    Need before-and-after pics. Stat. 8)
    Feb 2008
    Saratoga N.Y.
    729
    Bumpers are going out for new chrome so no after yet.
  1. FB rx7 BILSTEIN rear shocks
    By Leadpaw in forum Mazda Swap Meet
    Last Post: 12-07-2014, 11:53 PM
  2. Toyota Corolla KE70 Bumper and Publica KP3# Bumper (NOS)
    By a_fc3s in forum Toyota Swap Meet
    Last Post: 05-28-2013, 10:07 AM
  3. Mitsubishi Celeste Shocks
    By MrJake in forum Mitsubishi Swap Meet
    Last Post: 05-28-2011, 08:18 AM
  4. Datsun 620 NOS bumper front bumper
    By Heineken in forum Datsun/Nissan Swap Meet
    Last Post: 08-21-2010, 11:03 PM
  5. Set Koni Shocks
    By zulu in forum Toyota Swap Meet
    Last Post: 07-31-2010, 07:45 PM
