Results 1 to 4 of 4
Thread: Lower sill of death
    Feb 2007
    Napa Ca
    209
    If it makes you feel better, most Alfa Romeos have this sort of rust, but worse. Neither one of mine have rust there, but still, that is a common spot. My Datsun roadster had some rust there as well.
    Will
    Nov 2007
    UK
    80
    that sort of rot is common on uk classics, might be worth having a look through this thread:
    http://retrorides.proboards.com/index.c ... 171&page=2
    Mar 2009
    Australia
    627
    Hi Iain.... Im no Datsun guru but I dont think that matters anyhow. What model Datsun is it ?
    My advise if you're really serious about saving it is to carry out the following.
    1. Unpick the entire sill panel so only the inner remains.
    2. Have the door pillar, left kick panel and inner sill panel sandblasted professionally unless you have all the respiratory safety gear. It looks to me like someone has has a go repairing these sections previously. The only way to get it right is by blasting the inner sill clean if your after a permanent solution.
    3. I guarantee that the inner panel will have pinholes, these will need to be welded up or patched. The missing inner section will need to be fabricated.
    4. If its a popular Datsun like a 1200, 1600 or 240z you may be able to buy a replacement outer sill panel (either genuine or non genuine).
    5. Clean up and prime the inner sill panel with some quality waterproof metal primer that wont absorb moisture.
    6. Plug weld the outer sill panel or use a 3 phase spot welder (which I assume you dont have otherwise you wouldnt be asking for advise )
    7. Fish oil the cavity when finished.
    I dont think patching that sill is a good idea, I think the entire section needs to be stripped and replaced due to the extent of the rust. It'll probably look 3 times worse once its blasted however that'll give you a very good idea on what your dealing with up front rather than trying to patch bits and pieces as you find them.
    You'll want to dummy fit the panels on that side prior to plug welding to ensure or the panel gaps look right. It's probably a couple days work for someone who knows what they are doing once you have the sandblasting done. You can check out my restoration in the Mazda section for detailed ideas !
    Apr 2009
    Westminster CA
    72
    Quote Originally Posted by gypsy
    aaa you ausies have it nice! here in the states the 1200 is anything but "popular" :mrgreen:
  1. FS: RX2 Sill Chrome / Trim *No Reserve*
    By Mack in forum Mazda Swap Meet
    Last Post: 03-01-2013, 04:10 AM
  2. Death photos. warning, disturbing images.
    By Diego V in forum Mazda Garage
    Last Post: 12-24-2012, 07:03 PM
  3. Skyline C110 Coupe NOS sill panel
    By Flauski in forum Datsun/Nissan Swap Meet
    Last Post: 11-03-2012, 12:48 AM
  4. DEATH BEFORE DOMESTIC S30 STICKERS!
    By madFaber in forum Datsun/Nissan Swap Meet
    Last Post: 07-10-2012, 10:20 PM
  5. Death of the car enthusiast
    By liquid51 in forum Off-Topic
    Last Post: 11-08-2011, 01:42 AM
