Results 1 to 9 of 9
Thread: Fast idle problem
    Jun 2008
    Australia
    198
    Fast idle problem
    I've noticed that the engine (18r-c) seems to be idling higher than usual, I've tried to tweak the idle screw but to no avail. I suspected an exhaust leak somewhere but the engine does sound like its recieving more fuel at idle. Does anyone have any similar experience? Any help appreciated
    5,527
    Re: Fast idle problem
    Quote Originally Posted by Long
    I've noticed that the engine (18r-c) seems to be idling higher than usual, I've tried to tweak the idle screw but to no avail... the engine does sound like its recieving more fuel at idle.
    Sounds like choke problems to me? Are you sure the choke is opening all the way after it warms up?
    Jun 2008
    Australia
    198
    The choke is definitely opening all the way after the engines warm.
    Would the choke then be partially closed the next time it starts (cold start)?
    The engine is now stuttering when I try to turn it off. It sounds like its firing really slowly or just running on a cylinder.
    Apart from all this though, the car goes fine from idle
    Jun 2008
    Australia
    198
    |ENGINE COLD|
    choke closed
    choke fully opened by hand
    choke released
    upon release, the choke doesn't settle to fully close, is this normal?
    I'm experience weird engine shut down. After a decent drive the engine doesn't shut off instantly, it continues to stutter for a while before turning off.
    Oklahoma City
    762
    Your engine maybe 'dieseling' son. Does it continue to run after you have turned the key off? If that is the case, it is dieseling. Check this link for some causes and cures.
    http://mgaguru.com/mgtech/engine/ro101.htm
    Jun 2008
    Australia
    198
    thanks Okie, I'll have to look into these causes
    it seems that the high idle may be the cause of the dieseling
    Jun 2008
    Los Angeles, California
    573
    1972 Celica RA21
    I have exact same problem on same engine.
    Jun 2008
    Australia
    198
    Ok, The problem was that the fast idle cam was sticking due to grease and dirt. Took it to my carb guy to take it apart and clean it out.
    Solved the dieseling problem aswell
    Sep 2008
    Boston, Assachusetts
    900
    My Corona seems to be doing the same thing.. and mine has the 22R. After you give it a quick kickdown, it runs normal. 8)
  1. 1982 Corolla 3TC idle problem
    By fitz70 in forum Toyota Garage
    Last Post: 06-06-2015, 02:26 PM
  2. Fast Eddies Racing - South Bay Meet!!
    By mommabear in forum Events, Meets & Gatherings
    Last Post: 11-17-2012, 04:49 AM
  3. need info fast
    By datsun200l in forum Datsun/Nissan Garage
    Last Post: 10-20-2011, 03:08 AM
  4. 1978 corolla high idle problem
    By aRay_B.I.D.D in forum Toyota Garage
    Last Post: 05-14-2011, 11:25 PM
  5. fast j-tin have no clue what it is, well kinda but not sure
    By slickwrick in forum General Discussion, JNC News & FAQ
    Last Post: 07-10-2009, 09:22 AM
