Results 1 to 10 of 14
Thread: 1970 Honda N600 wheel bolt pattern
    Sep 2009
    Palo Alto
    9
    Hello,
    Does anyone know what the wheel bolt pattern is for the N600?
    Nov 2008
    Strasburg, VA
    508
    4x110.
    5,529
    Quote Originally Posted by E-AT_me
    4x110.
    x2 :tu:
    And they are tough to find wheels for... :P
    Sep 2009
    Palo Alto
    9
    Thanks guys!
    Jan 2008
    Melbourne, Aust.
    87
    4x110.
    x2 :tu:
    Shared with pre '75 Toyota Corolla?
    First Mazda RX-7 & R100/1000/1300
    but they're RWD so offsets a bit far off.
    I have to investigate Daihatsu Kei cars which seem to match & FWD so might be better.
    5,529
    Quote Originally Posted by 79cord
    The biggest problem with most of those are diameter sizes, not offsets (although they won't take a very wide wheel). The Corolla probably has some 12x4 steelies that might work? I'd guess a 13x5 is the smallest thing you can find for an RX7. What came on the R100?
    I have 13x5.5 wheels on my N600 and they are HUGE. :P
    Dec 2009
    sacramento
    141
    i currently have one 13" rx7 rim with a 205 50 13 toyo tire on the lr side of my z:
    this is what i will attempt to use, its the only oldschool rim i have, and they are near free a good cleaning and paint detail it might look ok, maybe with low profile 13"s it will work, i would like to use 10" but there is one one good tire avalible, the A008.
    Jan 2008
    North Carolina
    25
    Mini Lite will make you a set of wheels to fit the Honda 600 Sedan and coupes, 10x4.5 or 10x5 maybe even wider but space starts to end after a five inch wide wheel. Lots of ATV wheels out there also in this bolt pattern.
    5,529
    Quote Originally Posted by hondawizard
    I have some 12x7, -64 offset ATV wheels if anyone wants them. :P
    Quote Originally Posted by vwdmc16
    i currently have one 13" rx7 rim with a 205 50 13 toyo tire on the lr side of my z... this is what i will attempt to use, its the only oldschool rim i have, and they are near free a good cleaning and paint detail it might look ok, maybe with low profile 13"s it will work, i would like to use 10" but there is one one good tire avalible, the A008.
    I have a 175/50-13 on mine, also only one brand available, though... :x
    Still needs flares put on...
    If anyone needs them, I have some 13x5 Libres that will fit. :wink:
    Nov 2008
    Strasburg, VA
    508
    libres are SICK.. what i'd like to know is what are mini coopers bolt patterns? because that is where you find 10 inch tires.. and SSR makes a mini-specific wheel that i am pretty darn sure will work with the n/z's.
  1. Replies: 0
    Last Post: 04-07-2013, 06:31 AM
  2. Cressida bolt pattern?
    By mx63owneraz in forum Toyota Garage
    Last Post: 04-30-2012, 03:11 AM
  3. Enkei 92 15X7 PCD 4X110 Mazda bolt pattern 7 offset
    By FjFairlady in forum Wheels Swap Meet
    Last Post: 03-30-2011, 03:56 PM
  4. Need rod bolt torque spec for 8RC (1970) - corona mkII
    By jrb1449 in forum Toyota Garage
    Last Post: 02-15-2010, 09:37 AM
  5. help figuring out bolt pattern
    By s13smurf in forum Resto Tips, Wheels & Other Goodies
    Last Post: 08-03-2009, 09:02 PM
