Results 1 to 9 of 9
Thread: 18RG piston questions
    Melbourne Australia
    312
    Hi all
    Am in the middle of getting an 18rg rebuilt and it needs new pistons.
    Currently it has a bore of 89.5 and the pistons are marked 9.7
    My engine builder would like to go up in bore to ensure everything is good, so I will probably go up to 92mm bore and possibly 10.5 compression.
    Who do guys in the USA use for piston suppliers for these things?
    Toysport have some listed - has any one had experience good or bad with them?
    Thanks for any hints in advance
    Jun 2008
    Torrance CA
    277
    Ive used Venolia pistons from Toysport and they are good enough
    Melbourne Australia
    312
    Thanks for the feedback, much appreciated
    Apr 2009
    Central Fl
    196
    I would check around bout ToySport unless they have changed havent heard anything good bout them unless u live in Cali and can go see them in person
    Feb 2009
    Northridge, CA
    169
    I have some Venolia's and some Arias' here, though I wouldn't hesitate for a minute to use a set of JE's or CP's. All are very good quality.
    I can supply Venolia's with pins/clips & rings if you so desire, as I am a Venolia dealer.
    Melbourne Australia
    312
    I have an enquiry in with JE to see what they can do - we use them on race motors here all the time so I am confident about those.
    I have sent you a PM about the Venolia's BigSteve. Thanks for your help in advance!
    Feb 2007
    SO-CAL
    270
    Venolia builds the best stuff out there. And yes the make them. I've run those pistons in my 18RGs in the past. They're great people over there too. Make sure they throw in a T-Shirt if you order them.
    Feb 2007
    Socal
    10
    JE Pistons makes them. A bit pricey but excellent product.
    Feb 2009
    Northridge, CA
    169
    Quote Originally Posted by silverra23
    I sent you a PM with costs for both Venolia and Wossner pistons in the bore size and compression ratio of your choice. :tu:
  1. WTB: 18RG Piston's
    By shamboo in forum Toyota Swap Meet
    Last Post: 10-30-2012, 11:34 PM
  2. 2T REPCO piston set
    By in forum Toyota Swap Meet
    Last Post: 08-31-2011, 06:28 PM
  3. FS: 12R Piston Set
    By hampaslupa in forum Toyota Swap Meet
    Last Post: 01-18-2011, 04:12 AM
  4. Piston rings stuck onto piston?
    By estupidito in forum Honda Garage
    Last Post: 09-26-2010, 12:37 AM
  5. 18rg questions, and pics.
    By mark corona II in forum Toyota Garage
    Last Post: 02-01-2010, 07:10 PM
