Results 1 to 5 of 5
Thread: Need help to identify Vintage Mazda Special Tools
    Aug 2008
    Moscow, Russia
    39
    Please help me to identify Vintage Mazda Special Tools which I just bought on eBay:
    Here are the numbers - they all start with 49 :
    0636-100
    0259-440
    0223-440
    0223-440A
    0259-700 ( or 708 maybe)
    0221-030A
    0378-060
    0259-705
    0223-160
    0223-160B
    0820-260
    0813-310
    0259-310
    0221-251A
    These there are 2 of:
    0862-426
    0249-010
    0187-441A
    0813-245
    I need to know purpose of each tool & model application.
    Thanks in advance!
    Dec 2008
    Athens, Greece
    98
    Well, it seems that the first four digits are refearing to a model code. Normally, in parts, the four initial digits are corresponding to the initial model the part was used. For example a part like 0866-xx-xxx, means that the part could be exclusive for RX3 or initially used to RX3 but after that was used to other models. As a change part it could even replace a part of a model that appeared before, eg. RX2.
    I can recognise some model codes if it helps you. 0813=Cosmo/110s, 0820=R100, 0223=1500 (1966+), 0187=1000 (1965+. I can inform you on the others also according to mazda model list, but it doesnt seem to help you much.
    Aug 2008
    Moscow, Russia
    39
    Re: Need help to identify Vintage Mazda Special Tools
    I've found some numbers:
    49-0636-100 - Valve spring lifter (616 with 1586cc engine)
    49-0259-440 - Main shaft holder (4 speed manual gearbox for VC engine)
    0223-440
    0223-440A
    49-0259-700 - Front shock absorber cap nut wrench (RX-2 & 616)
    49-0221-030A - Ring gear brake (VC engine)
    0378-060
    0259-705
    49-0223-160 - Valve seal pusher (not sure about engine, for VC should be with "A" on the end)
    49-0223-160B - Valve seal pusher (not sure about engine, for VC should be with "A" on the end)
    0820-260
    49-0813-310 - Clutch disk centering tool (VC engine)
    0259-310
    49-0221-251A - Valve guide remover and installer (VC engine)
    0862-426
    0249-010
    49-0187-441A - Shift fork rod guide (4 speed manual gearbox for VC engine)
    0813-245
    I have a new in the packet rotor holder thingy - holds the seals in the rotor while you pull it out (before they invented rubber bands??). They had a lot of this stuff back in the day!
    Aug 2008
    Moscow, Russia
    39
    more numbers found:
    49-0259-440 - Main shaft holder (4 speed manual gearbox for VC engine, RX2 & 616 gearboxes also)
    0223-440
    0223-440A
    49-0221-030A - Ring gear brake (VC engine, 616 with 1586cc engine also)
    0378-060
    0259-705
    49-0820-260 - Stationary gear lock pin remover (RX2)
    49-0813-310 - Clutch disk centering tool (VC engine & RX2 also)
    0259-310
    0862-426
    0249-010
    49-0187-441A - Shift fork rod guide (4 speed manual gearbox for VC engine, 616 gearbox also)
    49-0813-245 - Rotor bearing expander (RX2, RX3)
  1. Help identify this Mazda (KMAA-125..?)
    By johno20b in forum Mazda Garage
    Last Post: 08-14-2014, 12:11 PM
  2. Various vintage OEM Mazda parts
    By kislui in forum Ad / Auction Finds
    Last Post: 10-29-2013, 11:51 PM
  3. Vintage mazda club videos. (Australia)
    By STB in forum Events, Meets & Gatherings
    Last Post: 07-05-2011, 12:43 PM
  4. Vintage Mazda Parts For Sale
    By pertano in forum Mazda Swap Meet
    Last Post: 07-16-2010, 09:08 PM
  5. Vintage mazda club day video.
    By magnusrx7 in forum Mazda Garage
    Last Post: 10-30-2009, 08:46 AM
