Results 1 to 7 of 7
Thread: What Rear gearing was an option in the 70's
    Mar 2008
    Yorba Linda, Socal
    115
    I have a 77 Arrow GT with a Direct-><-Connection LSD
    and I'm woundering what gears came stock as well as optional through
    the dealer as well as after market?
    Question I have is, my rear gear seem really tall, and the motor Revs really high while on the Highway?
    I think I have a 3:54?
    Nov 2008
    Georgia
    107
    3.9 to 1 with 1600cc with 4-speed, 3.545 with 1600cc automatic and 3.90 to 1 with 2000cc with 5-speed; 4.22 with 1600 and 5-speed; 3.55 to 1 with 2000cc and automatic.
    Mar 2008
    Yorba Linda, Socal
    115
    4.22 :shock: holycow!
    If this is right I should have a 3.90rear?
    How do I go about finding out my ratio with out cracking open my pumpkin? ops:
    5,529
    Quote Originally Posted by BlownArrow
    If you have a 3.90, 4000rpm in 4th gear should be right at 70-72mph. Try that first. If your RPMs at 70mph are lower, you have a lower number diff ratio, higher RPM, higher number ratio. :tu:
    Mar 2008
    Yorba Linda, Socal
    115
    My arrow was a 2000 5sp maual, so should be a 3:90 if joes right.
    But the Original owner (2 people before me) had a LSD instaled at the dealer when purchesed, but i'm not sure of the gearing?
    I thought there was a math-matic way to spin the wheel 1 rotation and count the drive shaft rotations then us that math stuff to figure it out?
    5,529
    Yes, there is. It's just never worked for me. :P
    The 70mph test is easier... 8)
    Feb 2008
    scappoose, or
    754
    You can also get gears off a sapporo rear end assuming yours is still a 180mm Give you the option of a 3.3 if you can find it
    if you get hard core enough to look inside
    3.54 has a 39 tooth ring with a 11 tooth pinion
    3.90 has a 43 tooth ring with a 11 tooth pinion
    4.22 has a 38 tooth ring with a 9 tooh pinion
  1. MX32 Cressida brake upgrade option
    By Banglabhai in forum Toyota Garage
    Last Post: 05-08-2013, 08:14 PM
  2. Toyota Factory Option Enkeis? (KE30 corolla)
    By swarf. in forum Resto Tips, Wheels & Other Goodies
    Last Post: 08-30-2010, 06:39 PM
  3. Replies: 2
    Last Post: 02-28-2010, 10:17 AM
  4. Got the dealer option stickers put on the '79 today...
    By qdseeker in forum Honda Garage
    Last Post: 02-12-2010, 06:55 AM
  5. Wacky Video Option Vintage Drag Racing! ~Videos~
    By Sr-FairladyZ in forum General Discussion, JNC News & FAQ
    Last Post: 06-24-2009, 10:27 AM
