Results 1 to 10 of 15
Thread: Removing overspray from lights?
    5,527
    Curious as to some of the methods you guys employ to do this. I bought a car with a dodgey paint job, but the worst of it is they got overspray on the lights/trim.
    The trim I can just scuff and repaint. But I'm curious what you've used to get the paint off the plastic lenses without damaging them.
    I've used acetone before, but it puts a haze on the plastic that takes forever to buff off. Simple Green? Paint thinner? Little help? :P
    May 2009
    Richmond VA
    220
    Try toothpaste. 8)
    Feb 2007
    Malaysia
    337
    I always use this product...
    Administrator JNC's Avatar
    Mar 2007
    Socal
    1,643
    i dislike buying products for one-time use
    so when i needed to restore some plastic lenses i wet-sanded them then used a series of paint polishing stuff i had and made the lenses look fantastic
    -Matt
    Aug 2009
    Los Angeles, CA
    182
    i used BRASSO polish to remove over spray since i had som laying around and it worked grate it even polished the crome...
    https://www.gtdawnbrite.com/shop/images/T/REC76523.jpg
    or you can go the cheep way and use paint thiner but you must remove the parts so you can get in every cranny...
    Jul 2007
    Sydney, Australia
    1,653
    x2 on the claybar.
    But the lenses can be polished quite aggressively
    Check out these instructions for shaving the lettering off MX5 tail lights. It's got instructions on how to polish up the lenses again after the initial sanding. Basically you sand with increasingly finer grades of paper, then do a final polish.
    http://www.miata.net/garage/lenspolish.html
    Jul 2007
    Midwest, USA
    285
    I'll suggest trying the least aggressive method first and being patient. The one thing I have noticed with polishing plastic is that once you do an aggressive polishing job with coarse polish and work down through the various grades, the polished finish lasts six months, the lens turns dull and rough looking, and you have to polish it over again. If you can get the paint off without breaking or deglossing the surface of the plastic, that is going to do the least damage and leave the lenses in the best condition.
    Overspray clay is a big chunk of play-dough for your right hand and a spray bottle of final inspection spray in your left hand. Mist on the spray, then wipe the clay through the moistened surface. It is meant to pull the overspray off any smooth surface. The clay is so sticky that you can not wipe it over the surface without the lubrication of the spray. It is not abrasive and will not leave any scratches or mar the surface, if used correctly.
    It is also something everyone should have next to the polish and wax on their garage shelf, because it is extremely useful for removing sap, tar, fallout, and anything else that drips onto a car and won't come off with soap or cleaner wax.
    5,527
    Quote Originally Posted by arsonist63086
    Got some of that in the shop. I'll give it a bash.
    I'm taking them apart anyway, so that's no big deal. Just not sure what paint thinner is going to do to the plastic. I've seen it haze some plastics, and not others.
    Quote Originally Posted by JT191
    Thanks for all the tips. I'll go through them until I find something I like, definitely starting with the easiest/least caustic first.
    I know with styrene (the car modeling background comes in handy once in awhile) you can soak the parts in Simple Green them the paint rubs off with a toothbrush. So if Brasso fails, I may go there next. :tu:
    Sep 2008
    Boston, Assachusetts
    900
    Have you tried that body work clay or Turtle Wax Rubbing Compound, that is usually good at removing any extra paint. :tu:
  1. Replies: 0
    Last Post: 09-12-2011, 05:11 AM
  2. Removing Brake booster Carolla SR5???
    By corolla 1975 SR5 in forum Toyota Garage
    Last Post: 02-26-2011, 08:09 AM
  3. Replies: 2
    Last Post: 07-20-2010, 01:18 AM
  4. removing front and rear winshields without damage?
    By eduardo i. in forum Resto Tips, Wheels & Other Goodies
    Last Post: 04-14-2010, 05:32 AM
  5. Removing Door Card: RT104 Corona
    By Long in forum Resto Tips, Wheels & Other Goodies
    Last Post: 03-24-2010, 07:56 PM
