Results 1 to 4 of 4
Thread: 76 TOYOTA COROLLA TE 51
    Guest
    [mod edit] please retype this minus the "all caps" tia
    fontana, CA
    173
    how long was it sitting? try the choke on the carb, might be stuck.
    check timing as well, is fuel getting to the carb? check the filter, then check your pump. disconnect the line going to the carb, crank the engine and see if any fuel comes out. if not change out the pump. if it still doesnt start it might need a carb rebuild.
    Guest
    IT WAS SITTING FOR ABOUT 7 MONTHS. I HARDLY DRIVE IT.
    Guest
    sorry for the caps......someoen on ebay told me those cars have a thermostat choke? does that sound right?. before it started right up the iddle would be high as soon as I rubbed on the gas it would die. The butterfly didint close it stayed open. also when i tried to push down on the butterfly door I could feel it getting stucked. I would have to use pressure to close it or if I move the throttle a litttle bit it would go down. I dont know if this helps. thanks for your help
  1. Toyota Corolla Wagon 77
    By Jonsubmarine in forum Toyota Garage
    Last Post: 05-13-2013, 08:51 PM
  2. Looking for 69 or 70 to 74 toyota corolla!!!
    By orlando3tc in forum Toyota Garage
    Last Post: 05-31-2012, 11:51 PM
  3. Toyota Corolla TE-71 parts
    By badboyboogie in forum Introduce Yourself
    Last Post: 01-17-2012, 01:15 PM
  4. 1973 Toyota Corolla
    By JNC in forum Toyota Garage
    Last Post: 10-29-2011, 11:33 PM
  5. 1985 Toyota Corolla FX-GT
    By far4ngn in forum Toyota Garage
    Last Post: 09-29-2011, 01:52 PM
