Results 1 to 9 of 9
Thread: First Post! need some advice for my corona
    Guest
    I just bought a 77 corona and im looking to get some cheap wheels. i dont want them to poke out. The wheels im looking at are 15x7 with a 0 offset. So basically im just asking if you guys think a 0 offset wheel would be ok?? i do not want them to poke out of the fenders
    Feb 2008
    Lynnwood, WA
    51
    They shouldn't poke really at all. Sit around flush, maybe a little less.
    5,527
    Tire size is very important here. What size were you looking at?
    Sep 2009
    Tucson, Az
    222
    You shouldn't have any problem with a 15x7 0 offset. i'm sporting a 15x8 with 0 offset but you will need to roll the fender lip up front and cut the front inner plastic shield as it rubs. Also you will have to roll the rear too.
    But with 15x7's don't think you will have this problem.
    what type corona do you have? I have '78 4dr sedan. Here's minewith 15x8's 195/50 up front and 205/50 for the rear. Check my tread rt105bong.
    Guest
    Quote Originally Posted by RT105BONG
    mines a 4 dr sedan. i love your stance man. As far as tire size goes im thinking about running a 195/55-15 all around. Thats about a whole inch less in diameter than the stock 185/75-14's which will make my highway revs higher which sucks and ill need to address the extra wheel gap.
    Sep 2009
    Tucson, Az
    222
    If the is you tire choice then you shouldn't 't have any problem with your 15x7's.
    that stance, I put a 2" lowering block at the rear and used a ford courier small truck springs(80's model) cut springs up front.
    Post pics!!Like to see your car.
    Apr 2009
    Central Fl
    196
    I have 15x7 all the way around on mine. 0 in the back and like plus 11 in the front and mine is hammered.
    The rear is 3in blocks with 2 leafs removed on Camaro shocks the front is cut 1 1/2 or 2 coils forget now but i have it cambered in all the way
    195/50 front 205/50 rear
    I had to pull the rear fenders a little for how low it is now befroe with just 3in blocks just rolled a little in the rear nothin in the front
    Guest
    Thanks for the info guys, ill get some pics up pretty soon. My previous car was a slammed mk3 jetta. I definitly want to lower my corona, I know i can get some longer U bolts made and put some blocks in the rear and the front i need to cut the springs. Besides just simply cutting the springs and maybe trimming the bumpstops is the front pretty easy to do?
    Oct 2008
    Forty-Fort, PA
    105
    ^yup, super easy ...
  1. Looking for suspension advice. RT104 Corona sedan
    By ColoradoKP in forum Toyota Garage
    Last Post: 06-20-2014, 06:10 AM
  2. Looking for advice
    By Skellington in forum Toyota Garage
    Last Post: 10-05-2012, 04:33 AM
  3. Need advice on rebuilding a 2TG
    By Murad in forum Toyota Garage
    Last Post: 05-21-2012, 05:39 PM
  4. Need advice
    Last Post: 08-03-2011, 10:57 AM
  5. Corona "post" Coupe
    By gaijinshogun in forum Toyota Garage
    Last Post: 08-02-2009, 01:22 AM
