Results 1 to 5 of 5
Thread: 2TC cap and rotor fit 2TG cap and rotor??
    Feb 2008
    Saratoga N.Y.
    729
    Its been a while since I tuned up my 2TG and don't remember about the dizzy cap.
    Will 2TC/3TC cap and rotor fit 2TG dizzy??
    My 2tg dizzy has the 2 push on metal side clips that holds the cap on the dizzy.
    Jan 2009
    Mauka
    66
    Re: 2TC cap and rotor fit 2TG cap and rotor??
    3tc cap and rotors are different, wont fit. It depends if your dizzy was originally points or electronic. Point type caps are a little smaller and will fit electronic type but will be a little loose. Electronic type wont fit points type. All 2tc rotors are the same.
    So yes 2tc will fit 2tg but there are 2 different cap sizes.
    p
    Feb 2008
    Saratoga N.Y.
    729
    OK thanks for the info. :tu:
    The one I have on now that I want to replace is a little loose.
    So I will get a early clip on points 2TC cap :tu: .
    Jan 2009
    Mauka
    66
    If there is a gap between the cap and the "anchor" for the clip then you will probably need the later 78/79 electronic 2tc cap.
    Feb 2008
    Saratoga N.Y.
    729
    OK well ordered an early one already so will have to try that first.
  1. Wooden Pendant Rotor Necklace
    By tomstwincam in forum Mazda Swap Meet
    Last Post: 04-25-2012, 12:56 PM
  2. WTB:Toyota 18R-G oil pump rotor set(new)
    By Levin37 in forum Toyota Swap Meet
    Last Post: 08-02-2011, 07:52 PM
  3. Spider Rotor Shirt
    Last Post: 04-24-2011, 01:24 PM
  4. Mazda 3 Rotor Twin Turbo Insanity.
    By in forum Ad / Auction Finds
    Last Post: 04-16-2011, 08:31 PM
  5. Replies: 12
    Last Post: 11-19-2010, 05:25 AM
