Results 1 to 4 of 4
Thread: Looking for suspension advice. RT104 Corona sedan
    Sep 2013
    Denver, Co.
    124
    Hey guys. I'm looking for advice on lowering my RT104 sedan. I'm planning on doing King 30mm drop springs on the front but as far as the rear goes I'm unsure. Looking for about a 1" drop in the rear.
    Also any advice towards poly bushings or anything like that would be great too.
    Apr 2013
    NORWAY
    42
    Re: Looking for suspension advice. RT104 Corona sedan
    unsure if you got leafs in the rear or not? if you do you could just get someone to make you some lowering blocks and buy 4 longer u bolts--> low
    made mine in like 10 mins just to see how it would look, works great
    An RT104 would probably have leaf's for the rear's. Corona's started to have rear coil's from RT130 onwards AFAIK. So yeah, you should use lowering blocks.
    Mar 2012
    Long Beach
    78
    Not sure if the RT104 front coil springs are the same for an RT105, but I found other RT105 owners who used early 1980's Ford Courier truck coils and cut them. I used them on my RT105 and they worked great.
  1. 1976 RT104 Toyota Corona
    By RT104 in forum Introduce Yourself
    Last Post: 10-09-2012, 01:18 PM
  2. W40 - W50 Transmission swap RT104 Corona
    By Long in forum Toyota Garage
    Last Post: 12-09-2011, 08:45 PM
  3. 1974 RT104 Corona GT restored
    By rt104gt in forum Toyota Garage
    Last Post: 08-25-2010, 12:18 AM
  4. Removing Door Card: RT104 Corona
    By Long in forum Resto Tips, Wheels & Other Goodies
    Last Post: 03-24-2010, 07:56 PM
  5. RT104 Corona 22R alternator upgrade?
    By superboosted in forum Toyota Garage
    Last Post: 12-11-2009, 02:44 AM
