Results 1 to 4 of 4
Thread: T50 Transmission Question/Help
    Feb 2013
    Pennsylvania
    47
    Did a search - didn't see any results.
    Does anyone know if the newer 86+ C50 transmission rebuild kits will work, at least in part, on the pre 85 T50 transmissions? I am trying to piece together a rebuild kit and I have some bearings so far but curious if I could use the synchros and other items from another kit to make it complete. Same with the W5x series trans.
    Any help appreciated!
    Jul 2011
    Norway
    51
    Re: T50 Transmission Question/Help
    belive they share syncros With some w boxes . Doubt C50 parts will be any good.
    Find partnumber of your rings on toyodiy and use the crossreferece function
    Then youll know for sure wich ones fit
    Feb 2013
    Pennsylvania
    47
    thanks for the tip on toyodiy. I will give that a shot. Part numbers can be somewhat elusive though as sometimes they change part numbers or different companies use different part numbers making it hard to cross reference. But worth a shot!
    in the meantime, if anyone else has any direct experience let me know. thanks!
    May 2011
    Netherlands
    170
    The newer T50's have a stronger incoming axle bearing. Dont know if the size share same dimensions of the older bearings.
  1. Transmission question
    By crown69 in forum Toyota Swap Meet
    Last Post: 09-25-2014, 11:58 PM
  2. Transmission help
    By AlexRT in forum Toyota Garage
    Last Post: 01-05-2014, 05:50 PM
  3. WTB w58 Transmission
    By theunstated in forum Toyota Swap Meet
    Last Post: 03-02-2013, 10:24 AM
  4. 1972 240z Transmission Swap Question
    By Lugnut in forum Datsun/Nissan Garage
    Last Post: 01-10-2013, 07:29 PM
  5. transmission question...
    By pony559 in forum Toyota Garage
    Last Post: 04-19-2010, 06:02 AM
