Results 1 to 10 of 11
Thread: Tore's RS50--->MS50 4M engine Swap +ms85 diff/driveshaft
    Apr 2013
    NORWAY
    42
    hey! im currently in the process of taking a 5R out of a rs50 and putting a 4m in!
    here si a pic like the day after we bought it.. ( last year)
    4M-tailshaft,diff donor car
    both engines out and on the floor
    diff comming out
    no rust at all
    such clean
    going out
    both out
    got the handbrake loose
    new diff in
    put the tires on and found out i needed to shorten a stag to get it in the right place... the mount for this stag is 2,5 cm to the left
    perfect
    got the tailshaft mount in ( i only need to drill 4 holes) and the tailsaft in, engine in, need new engine and gearbox mounts then its just electrical and small issues..
    Apr 2013
    NORWAY
    42
    Re: RS50 to MS50, 4M/tailshaft/diff from MS85 project
    motormounts done
    dad bought us som stuff.. new exhaust, brake fluid, cooling, filter, brake shoes, wiring, motor oil.. etc..
    painted engine mounts and some more and stuck engine back in
    moved the coil and fuel pump to teh left side, and mved the wiper fluid container to the right, going to move the battery case to the left aswell..
    freaking everything is on the other side...! extended the dynamo cables and the coil, got a bit more to do..
    Apr 2013
    NORWAY
    42
    first startup!
    https://www.youtube.com/watch?v=i4-AyXZJK5M
    cleaned the carb
    botled the fuel pump and coil onto the fender, the wiring looks messy but i had to toss it over there because i was going to make the battery tray..
    after some discussion with my dad we decided to use the MS85 radiator, so he want on and made it fit..
    original vs ms85 radiator.. looks good!
    i tink i need to stiffen this bar somewhat..
    Apr 2013
    NORWAY
    42
    when i got home from a school trip yesterday i found out that dad had done a lot, he had fixed the throttle, changed brake shoes, fixed the clutch , gearboxmounts, cooling etc.. so then we put some lights on it and had a test ride need to adjust the ignition its backfiring a lot!
    soo.. i started working to get the grill on the car, to do that i had to modify the hood opner, since the radiator sits 5cm ish more to the front we had to turn the hod opner arround... but then the grill would not fit and the wire had to go on the other side.. so i made a lever instead..
    going to stick it out through the grill
    needs to do something with it to be less pointy and sharp..
    oil cooler mounts
    looks good
    painted all the bare metal and mounted the whole grill.. but the badge is missing, it needs something there its so empty...
    May 2014
    Helsingør Denmark
    95
    Looks great. I am thinking of doing a swap of either diff or gearbox so that I get a better ration for when driving on highway. What options are there for a MS55 2300S from 1970?
    Rgds
    Apr 2013
    NORWAY
    42
    an MS55 i'm not shure about, but in this case the talshaft from the rs50 did not fit the 4m and teh tailshaft of the 4m did not fit the diff, so i had to swap the entire driveline...
    decided to polish teh wheels, before pic
    i NEED to get a badge in the grill, it looks so empty
    new brake pumps for the rear..
    Feb 2011
    Bay Area, California
    533
    The car looks great! I like the polish on the wheels
    Apr 2013
    NORWAY
    42
    Thanks
    changed the brake pumps in the rear the other day , and changed the exhaust gasket, runs good and sounds awesome
    also bought myself a Corolla for 3/4 of the price of a new front wind screen, and i needed a new windscreen for mine, turns out to be pretty rust free so ill save it for a future porject previusly had 230 ish HP in it so its build for 200hp ish converted to hydraulic clutch aswell
    some pics with my brothers RS56
    Apr 2013
    NORWAY
    42
    valve adjustment
    deluxe grill mounted
    cleaned, adn sanded, 2 of the thingis polished
    looks heaps better
    interior looking as awesome as always
    when over the tires with a white marker
    Apr 2013
    NORWAY
    42
    Re: Tore's RS50--->MS50 4M engine Swap +ms85 diff/driveshaf
    tried making my own site.. dunno how it worked out... :roll:
    http://garage-tore.weebly.com/
  1. 77 celica engine swap
    By Blackguy in forum Toyota Garage
    Last Post: 08-31-2014, 04:50 AM
  2. trade welded diff for stock diff mx87 cressida
    By xsquintsx in forum Toyota Swap Meet
    Last Post: 07-01-2011, 05:17 PM
  3. E series diff possible swap to F series?
    By supermegaultra in forum Toyota Garage
    Last Post: 01-25-2011, 02:26 AM
  4. 77 corolla engine swap
    By bigblackcat in forum Toyota Garage
    Last Post: 08-26-2010, 02:23 PM
  5. What should I do (engine/transmisson swap)??
    By jacbo in forum Mitsubishi Garage
    Last Post: 08-19-2009, 10:18 PM
