Results 1 to 10 of 10
Thread: 77 corona headlight(4 sealed beams)question...
    Oct 2008
    Forty-Fort, PA
    105
    So I changed out the middle lights(highs) with bosch units from a benz(replaceable bulbs) now when i turn the lights on,they always light up,even with just the lows...
    Should go..
    Low beams---outside lights/lighted inside lights off
    High beams----outside lights/lighted second stage and inside(highs)lighted.
    how it works now(wrong)
    Low beams---All lights lit
    High beams---All lights lit and the outside goes to low stage?
    Help!I have not changed the wiring,and it worked fine before the install of the benz inside fogs..
    Oct 2008
    Forty-Fort, PA
    105
    maybe the new fogs(inner) dont have the right resistance? Help,I dont unerdstand!
    Dec 2007
    Detroit
    696
    I had the same issue with my '74 Celica, which someone had installed those lights on. Pertano on here told me that this is what happens to everyone who uses those lights, I guess. I didn't pry for an explanation, but at the very least, it's not your car at fault here. :lol:
    Oct 2008
    Forty-Fort, PA
    105
    Well there has to be a reason?it has to be a wiring difference,or the outside lights need to see resistance? Pertano? Somebody?
    Feb 2008
    Lynnwood, WA
    51
    Is it a 3 prong (pin) style or just two? I believe our high beams are only 2 wire, but I don't think there's a 3rd wire on the plug.
    Oct 2008
    Forty-Fort, PA
    105
    jUst two..factory Benz foglight
    Jun 2008
    Torrance CA
    277
    I used to have an adapter sold by Cibie in Japan that was to prevent the lights to stay on when the low beams were on. I dont know why but that is what I used and never had a problem. On another note, you should run relays to your headlights to make them brighter if you have not done so already. H4 or H1 bulbs require more juice than the standard wiring can handle.
    Oct 2008
    Forty-Fort, PA
    105
    ^any more info on this?or a how to?
    Sep 2009
    Tucson, Az
    222
    Did the same thing on mine. tried to switch polarity and it almost burned my car down(it shorted the wire. Dumb of me!! :evil:
    Robakun, you still remember the adapter you bought as well as the relays you used?
    Anyway, since I almost destroyed my wirings, Now my low beams just stays open all the time.
    Yes, I think it need more juice than the ordinary set it has. so now, I'm bringing the car to an elecrician to install relays. Can you use the relays from the bimmers? Or jsut any standard relays one can get at autozone?
    thanks.
    Feb 2009
    Northridge, CA
    169
    Some of those housings have isolation issues to ground. I have had this happen before with some old E-spec Hellas on a FJ62. Remove the bulb from the housing, turn the light on with the bulb out, and see if the problem goes away. If it doesn't, check the factory headlight relay or switch aren't melted/shorted across.
  1. Anyone have 3SGE beams wiring diagrams?
    By Jonv in forum Toyota Garage
    Last Post: 07-07-2013, 06:12 PM
  2. RA45 GT Celica with full on race beams
    By Celica RA45 in forum Toyota Garage
    Last Post: 04-21-2013, 10:49 AM
  3. question about 81 corona
    By 81corona in forum Toyota Garage
    Last Post: 02-23-2011, 01:02 AM
  4. Beams 3sge f/s
    By brownmagic in forum Toyota Swap Meet
    Last Post: 12-20-2010, 03:09 PM
  5. HID housings for sealed beam
    By adamyee in forum Toyota Garage
    Last Post: 10-30-2010, 01:33 AM
