Results 1 to 2 of 2
Thread: RX-2 clutch pedal trick.
    Dec 2007
    West Palm Beach, Florida
    46
    I was working on my pedals on the M30 in preperation for the 5 speed and had a flashback to 1982 and a mazda RX-2 that started life as an automatic.
    I put a 13-b from my RX-5 cosmo into it and I needed pedals to work with the 5 speed.
    Brake pedal was easy....cut it off and just leaned in while kneeling and bent it over toward the accelerator pedal.
    I had a clutch pedal but no bracket and the donor car was gone!!
    While cleaning up, I slid one of the internally threaded engine dowel tubes into the clutch pedal end and found it fit perfectly into the bushing.
    Upon examination of the pedal set, I decided to just remove the nut for the brake pedal pivot bolt and screw the dowel pin over it and use the dowel as the nut.
    Then the clutch pedal slid on and I clamped a mini vise grip to keep it from sliding sideways and off the dowel.
    Drove it for 4 years that way without a problem.
    I also knew where a mini vise grip was in case I needed one.
    Just figured I would share what might help get a car onto the road temporarily (or permanently) rather that let it sit for want of parts.
    Feb 2007
    SO-CAL
    270
    For my RX4 I used pedals out of a ford courier. Same exact pedal. Just left the cage in the car and only pulled out the bolt that mounted them and shims as well as brake and clutch pedal. Very simple conversion.
  1. WTB: AE86 Clutch Pedal Assembly
    By mr2_ftw in forum Toyota Swap Meet
    Last Post: 06-13-2013, 05:20 AM
  2. Replies: 4
    Last Post: 01-28-2012, 06:48 PM
  3. MX32 clutch pedal options?
    By okibum03 in forum Toyota Garage
    Last Post: 05-13-2011, 07:26 PM
  4. MX62/3 Clutch Pedal ???
    By aikane in forum Toyota Garage
    Last Post: 03-15-2011, 06:04 AM
  5. WTB - clutch pedal assembly
    By ghostking in forum Toyota Swap Meet
    Last Post: 09-01-2010, 07:05 PM
