Results 1 to 10 of 15
Thread: 1970 MS55 Crown
    Oct 2011
    Alberta
    171
    1970 MS55 Crown
    I thought I would start a thread for a car I just purchased from JNCer Yotaman. It will make a beautiful addition to my Cressida once it is fully refinished. It certainly isn't in the best shape but it has some massive upsides. All the glass is intact, the original motor runs, and it is a factory 4spd, which is simply unheard of in Canada. The car isn't at home yet, but here are the pictures I have so far, showing the good and the bad.
    There are a fair amount of half-done repairs and bondo on the body panels but the frame seems solid. Aside from the driver's side floor pan and the rockers most of the body seems salvageable. We'll know more once I get it home and set to work with a wire wheel and a grinder.
    More to come, comments and suggestions are more than welcome. The short term plan is to shore up the body as best as possible to prevent further corrosion. A full body restoration will be done once I finish school, for now I just want to get it driving again and looking decent.
    Jan 2009
    Curaçao
    51
    Re: 1970 MS55 Crown
    Nice pick up. Gotta be committed when dealing with rust, 90% of the time it turns out to be worse than you think initially.
    Look at my 1988 YN55, this was a LOLWUT moment after removing the carpet:
    Feb 2008
    Saratoga N.Y.
    732
    Re: 1970 MS55 Crown
    Is the dashpad good :tu:
    Oct 2011
    Alberta
    171
    Re: 1970 MS55 Crown
    The dash pad is so good it's invisible! It was removed at some point, probably due to horrendous cracking. The interior of the car will be removed once it is in my garage and the berber that is standing in as carpet will be removed as well. The pans look alright other than the driver's. I do expect to find more, however.
    Oct 2011
    Alberta
    171
    Re: 1970 MS55 Crown
    The car is up on stands now and we are getting better acquainted. It has become clear that this car needs a LOT more work than first anticipated, (surprise surprise) so the plan now is a complete rebuild. The driveline is still solid, or so it seems, and the frame needs to be boxed in at one point to strengthen it. For the most part, though, we seem to have a solid starting point. Pictures and more details to come later this weekend.
    Oct 2011
    Alberta
    171
    Re: 1970 MS55 Crown
    Alright, as promised here some more pictures of the journey so far. The car has already has far too many "repairs" in its day to try and patch it back up. It's time to get serious on it, so I am going full out in stripping it down, just shy of going frame off.
    On the truck headed home
    Poking around the car and looking at the condition of the rear end I decided that this would probably be the most difficult and most frustrating section to work on, so I decided to start with it while enthusiasm is still at its peak. It didn't take much time to show that I have a TON of work ahead of me.
    The angle of the sun helped show just much attention this side will need
    The passenger side has seen a bit of metal put in. I'm not a metal expert, but if I had to guess I'd say that isn't automotive metal. Still, it was shaped quite nicely. Thoughts from anyone on welding that piece in properly and re-using it? Will it be appropriate metal if prepared properly?
    The driver's side has a piece from a different car patched into it, held together with rivets. The unblemished and shiny paint underneath the marker light is probably the last bit left that shows how nice the paint once was.
    The trunk floor isn't terrible, but it isn't great. The spare tire well has no floor, it was patched with sheet metal and, again, rivets. This will be removed and replaced with a proper piece. The passenger side of the trunk has a very large hole where it attached to the wheel well, and the entire seam along the fender is completely gone, with another hole under the tail light. Both had been lazily filled with a fibreglass which came out in comedic blobs.
    Here is the current state of the car. Trunk lid removed for refinishing, tail lights and trim have all been removed from the back of the car. Took a ridiculous amount of effort since a previous owner had lost some hardware and simply..attached everything with more silicone.
    Next up: I need to get the bumper off properly. The bolts sheared off on the one side, so that was easy enough, but the chrome bolts spun on the driver's side rather than the bolt itself shearing off so that will take some cutting.
    The rear corner trim of the tail lights is also being held in by silicone and I am having a heck of a time removing it without causing damage. Any tips from anyone on this?
    Once it stops snowing I'll be back at it and I'll get the bumper off and properly strip off all the fibreglass, paint and bondo. More to come.
    Jan 2009
    Curaçao
    51
    Re: 1970 MS55 Crown
    That left rear 1/4 panel looks bad indeed. Good luck with the repairs, looking forward to the updates.
    Jul 2012
    Kentucky
    111
    Re: 1970 MS55 Crown
    Yowza, that rust...but what a worthy project! Manual Crowns are such a splendid rarity.
    Oct 2011
    Alberta
    171
    Re: 1970 MS55 Crown
    I was able to spend another few hours with the care today, so here is a quick summary of the new progress.
    Body filler. Dear god the body filler. If anyone has a better method for removing body filler (up to 5mm thick in some places) beyond just grinding the crap out of it PLEASE feel free to share.
    Continued to grind down the passenger quarter. More and more of it just kept falling off in large chunks of fibreglass. It has become apparent that my only option here is going to be cutting a big chunk of the panel off to expose the inner fender wall so that I can seal that up as well. Then I will have to reconstruct the outer panel and put it back together. My main worry with that is being able to maintain the original dimension of the wheel well, so much has rotted away.
    Which made the true state of the trunk and fender well even more apparent..
    And then I found some frame rust which will have to be boxed in..
    And then I got super discouraged. So I decided to take on some work with immediate visible results and finished taking out the sound deadening on the front floor and removed the interior from the front half of the car.
    Then I relaxed and had a beer in the back seat.
    And lastly, a technical question for everyone. My brake lines have failed somewhere and I am not sure where. I am going to replace the lines for the whole car (45 years old after all) but there is this..thing..half way down the body. Does anyone have any idea what this rusted out husk of technology is? When I re-run the brake line can I simply tun a straight line or is this some obscure part I will have to replace?
    Cheers all
    Nov 2010
    NC
    289
    Re: 1970 MS55 Crown
    It looks like a rear brake pressure regulator/proportioning valve. It controls brake bias. There are a number of aftermarket options for them.
    Heres what I bought to replace my valve.
    http://trackspeedengineering.com/produc ... cloa36b544
    Heres another option
    http://www.speedwaymotors.com/Adjustabl ... Ogod1FsAsw
  1. MS55 1970 Crown Deluxe S from Denmark
    By Holmen in forum Toyota Garage
    Last Post: 09-02-2015, 06:34 PM
  2. User manual for a MS55 1970 Crown 2300 S Deluxe
    Last Post: 06-14-2014, 04:48 AM
  3. Replies: 69
    Last Post: 08-01-2013, 08:10 PM
  4. WTB 1970 MS55 Crown trunk trim, last piece I need!!!
    By te37jake in forum Toyota Swap Meet
    Last Post: 03-27-2013, 05:13 PM
  5. 1970 MS55 Crown has arrived!
    By palatine in forum Toyota Garage
    Last Post: 09-04-2012, 02:28 AM
