Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Supra MKII, need guidance quick before they scrap her!
    Oct 2009
    Ohio
    34
    I just found a beautiful silver 85-86 MKII with absolutely no rust and the cleanest body ever.....but she has a blown motor & is sitting in our local junkyard. I asked them what they where going to do with it, & they said they where going to scrap it out because the only motor they found cost $2500 (they actually bought the car to repair it). Heres where I need you pros to come in, how much could I expect to purchase one of these motors for? How much should I expect to pay for this car? And finally, Ive heard the 7mge swaps easy into this car, is that true?
    Aug 2009
    salt lake city
    322
    ive been looking for a clean mk2 for a while.. save it and put a 7mgte in it
    Dec 2008
    Massachusetts
    38
    You would want to pay as little as possible but A clean solid body MKII in my opinion could be worth as much as 1G (clean int. and ext.) and as far as engines the 5mge is a very nice engine but I would consider swapping a stock 7mgte as it is a fairly easy swap.
    Nov 2009
    Tacoma, WA
    118
    You can find 5mge's everywhere it seems. Wrecked 85-88 Cressidas would be what you should look for to pull the motor out of. I got a 5M and trans for $200, the deals are out there just have to find them.
    Aug 2009
    San Diego, California
    70
    7M-GTEs are good engines, as are 5M-GEs, but 7M-GEs seem to be even more common, I'd go with that engine.
    Guest
    Try to get them to sell it to you with the blown motor, no point in paying them to fix something you may want to change.
    I personally wouldn't spend the time or effort to swap in anything but a JZ series motor, but that's just me. A cleaned up 5m with a header and cams is a neat powerplant, though.
    Oct 2009
    Ohio
    34
    well i called them back and they want $800 for the car which seems a little steep for me considering they are just going to scrap it. I want to go back and get some pics of the car and check the interior out more. I didn't even think to see if it was standard or automatic, automatic would be a deal breaker for me. As it sits right now, I would need them to come down in price more before I would consider buying it from them (shes worth it, but not much funds are available)
    Oct 2009
    Ohio
    34
    Quote Originally Posted by Zach90Turbo
    thanks for the suggestion, after reading your thoughts I priced the 1JZGTE and it seems to go for the same price as a 7mgte which got me thinking why not? After googling mkII supra 1JZGTE swap with no hits I am wondering how easy this swap would be. I also have to take into consideration if the 1JZGTE will bolt up to the stock mkII transmission
    Nov 2009
    Tacoma, WA
    118
    The JZ series will not work with a W series trans as far as I know or alot more 4x4's would be running 2JZ's instead of the 5M and 7M swaps. I would look into a 2JZ swap over the 1JZ just because of ease of getting replacement parts. But I'd pay no more than $500 for the car. They will probably get about $300-$400 for the scrap metal. And unless your competent in wiring or have the money to pay someone to do the custom wiring for a swap I'd just put another 5M in it for now.
    Edit: From what i seen in another thread the W series may work but I'm not sure what's needed for that.
    Oklahoma City
    762
    If the interior is good and there are no rust issues, 800 is not bad. I picked my MkII up for 600$ It is a runner with a good tag and title, but no interior and a bunch of other issues. Easiest swap is a good 5M. 7MGTE will be between 1-3K depending on what you get with the engine and what you do with the engine. 7MGE swap makes no sense, not when 7MGTEs cost only a couple hundred more. JZ swap expenses mainly rely on where you get the engine from, but figure 2-5K. All the swaps besides the 5M will require at least a tranny swap as well. For rust issues look at the usual places, hatch, quarters, rockers etc. Also if possible, pull the back seat and carpet. Sometimes the MkII rusts out where the rear wheel well meets the chassis floor. This is where the sunroof drains to and sometimes they get clogged and back up. I have a 7M sitting around with a new headgasket(pretty much a requirement) and have not put it in my MkII just because I know that a GTE swap will only cost a couple hundred more. Got everything for that swap except for the GTE block. Even if it turns out that it is auto, as long as you are dropping in a new engine. A new tranny will not add that much work to the project. You can even run it off the auto ECU with some minor mods. Pedals can come from any celica or supra of the same gen. Same with clutch cylinders and such. Only thing on the interiors of these that are made of un-obtainium are the dash vents. Dashes can be found, but they can be expensive depending on the color.
  1. MkII Supra in Bowling Green KY
    By TheBirdmanJD in forum Junkyard Finds
    Last Post: 02-05-2015, 09:55 PM
  2. WTB: MKII Supra stock front springs
    By Nadal4Hand in forum Toyota Swap Meet
    Last Post: 01-18-2014, 11:00 PM
  3. MKII Supra JDM turn signal lenses
    By TEMPEST in forum Toyota Swap Meet
    Last Post: 07-28-2012, 06:33 PM
  4. Replies: 5
    Last Post: 06-12-2012, 06:29 PM
  5. Replies: 8
    Last Post: 11-20-2009, 08:20 PM
