Results 1 to 3 of 3
Thread: s30 strut setup
    Oct 2013
    s30 strut setup
    I have a 76 280z with a 3.1L stroker with triple 45mm. I'm buying techno toy's ground control coil springs trying to figure out what struts to run but I can really only find KYB's and k sport coilover. I was planning on running koni yellows but cant find them.
    Dec 2013
    Colorado Springs
    Re: s30 strut setup
    On the T3 website it says that's their coilover conversion is supplied with Koni dampers. I haven't been able to find where to purchase just the Koni dampers either, maybe you could contact them and see what their source is? Koni's website doesn't list them either.
    Other than that it seems like Tokico Illuminas are a popular strut upgrade for Zs. They are readily available through the Zstore.
    Aug 2008
    Re: s30 strut setup
    You should probably also know that early 240Zs have a smaller ID strut housing that 280Z which makes it difficult to find struts for.
    Most people looking to put some kind of coilover on an S30 go with the 280Z struts because of its bigger ID.
    Suspension geometry / hubs / ball joints /brakes are interchangeable btw between 240Z and 280Z
  1. 2tg setup for sell
    By 91ma70 in forum Toyota Swap Meet
    Last Post: 03-23-2014, 04:50 PM
  2. wtb: 2TG oem dual carb airbox setup
    By 4agshoob in forum Toyota Swap Meet
    Last Post: 05-29-2013, 02:54 AM
  3. RA24 Complete Air Conditioning Setup
    By fressssssh in forum Toyota Swap Meet
    Last Post: 05-26-2013, 09:52 AM
  4. FS L20 OEM single carb setup
    By wookieballa in forum Datsun/Nissan Swap Meet
    Last Post: 09-30-2012, 04:41 AM
  5. SOLD 2tb setup
    By RollaAce in forum Toyota Swap Meet
    Last Post: 01-18-2011, 12:32 AM
