Results 1 to 10 of 10
Thread: 5M aftermarket weber/holley/etc options?
    Aug 2013
    Qld, Australia
    6
    Hey guys,
    ive searched and searched to no avail, so I thought I would just start a thread.
    I've got a 77 mx32 Cressida, which has been fitted with a 5M engine. It goes great, but having some problems with the stock carby set up (as well as having 50 million ugly and unnessessary hoses and tangled mess hanging off the side)
    I'm wondering if there's any options for an aftermarket carby setup for this engine?? (something old school cool, similar to a triple weber set up etc would be rad) anything at all, I really want to get rid of this stock set up and clean up the engine bay as much as I can.
    Any help at all is greatly appreciated
    Kez
    Jan 2009
    Curaçao
    51
    Re: 5M aftermarket weber/holley/etc options?
    Back then there was someone on Classicrown that mentioned one of the Weber carbs that was pretty much bolt on with little modification to the insulator plate holes. I don't remember which model Weber it was though.
    Sep 2010
    australia
    39
    Yes that would have been me way back then lol.As you are from Aus like me then this should be easy.Find a Weber from either an XE or XF Falcon,Im unsure off the top of my head what size it is but all you need to do is enlarge or slot the bolt holes to suit the M manifold,Change the manifold studs for longer studs or if your lucky to get the Falcon manifold as well,use the studs from this as they are metric like the M manifold.NO ADAPTER IS REQUIRED.Then its throttle linkage setup which I cant tell you how to do as this was done on a 40 series Crown and Re-Jetting.
    Cheers Brett.
    Jan 2009
    Curaçao
    51
    Ha, nice! Whatever happened to CC, did it die out with the switch to Multiply?
    Aug 2013
    Qld, Australia
    6
    AWESOME! thanks heaps for the heads up, this is just what we wanted to find, something that could fit with minimal modifications etc.
    ill have a look around and see what I can find
    thanks again, it's great to know some people are still willing to share their knowledge!
    Aug 2013
    Qld, Australia
    6
    does 34ADM ring a bell @crowncustom?
    Sep 2010
    australia
    39
    That would be the one mate.Im happy to share my 25-30yrs of Toyota experience.
    Cheers Brett.
    Jul 2013
    5
    if any one has interest i actually have the hks surge tank for a 5m triple webber carb set up be pretty cool if someone wanted to do a carb turbo project ! http://www.dorikaze.net/showthread.php? ... a-inline-6
    Nov 2009
    Seattle, WA
    115
    Quote Originally Posted by strdz
    That's incredible. But... where would one get a proper intake manifold for such a set-up? Did HKS make one?
    Apr 2012
    Kentucky / California
    28
    Yeah, HKS made a whole setup for the 5M. It uses special cams and a rear mount cam driven distributor.
    This guy has the full setup.
    http://www.celicasupra.com/forums/showt ... cked-setup!
  1. FS: ae86 and 4age stuff HKS, Weber, MSD, Holley
    By towat168 in forum Toyota Swap Meet
    Last Post: 04-04-2013, 02:43 PM
  2. Is this OEM, Aftermarket, or Custom?
    By cesariojpn in forum Toyota Garage
    Last Post: 12-28-2012, 05:18 AM
  3. FS: Ton of RX-3 Parts. New, used, OEM & Aftermarket.
    By nocargreg in forum Mazda Swap Meet
    Last Post: 12-19-2012, 12:35 PM
  4. WTB: 2nd Gen R Bumper (NOS or New Aftermarket)
    By gen2twincam in forum Honda Swap Meet
    Last Post: 11-21-2010, 05:14 PM
  5. Holley 465 CFM for 12A Streetport
    By Apple Guy in forum Mazda Swap Meet
    Last Post: 10-22-2010, 04:26 AM
