Results 1 to 7 of 7
Thread: Chassis question
    Jun 2008
    ohio us
    102
    Chassis question
    Is the ae70 the same as the ae72? besides one is right hand drive and the other is left a seller on eBay is saying lowering springs for ke70/ae70 won't fit the ae72?
    May 2012
    Louisville, KY
    66
    Re: Chassis question
    Are you saying that the Seller claims the springs fit either KE70 or AE70? If so you should be fine.
    Jun 2008
    ohio us
    102
    They are brand new lowering springs for the ae70 or ke70 on eBay they are called king springs they are out of Australia I looked up king springs and on there web site they have lowering springs for the corolla does anybody know about these in Australia ?
    Jul 2012
    439
    I believe the ae70s come with rack and pinion steering. Springs /struts should be the same if you are talking aftermarket.
    Dec 2011
    Oxnard Harbor, CA
    64
    Yes. They will fit. Most of your Toyota struts were 51mm, especially on the same chassis code a7x, the big difference is engine, and body (coupe, liftback, more door). Underpinnings usually stayed the same, I know on later Corollas like the hachi, and on my second gen Celica, they did.
    Mar 2007
    Pac NW
    500
    from memory(may be faulty)... they may not.... the strut mounts changed in mid production, 1980, and 81 models have a slightly different upper strut mount than the 1982-83 - this I know for sure. What I'm uncertain about is I seem to remember one of the spring seats on the struts changed a little too... this would mean the earlier springs don't fit the later models.... but this I'm uncertain about....
    From Toyodiy....
    48131 SPRING, FRONT COIL, RH
    48131-12710 (08/1979 - 07/1981) 1 $132.60
    48131-1A120 (08/1981 - 07/1982) 1 $125.59
    48132 SPRING, FRONT COIL, LH
    48131-12730 (08/1979 - 07/1981) 1 $145.24
    48131-1A130 (08/1981 - 07/1982) 1 $126.12
    Sep 2010
    australia
    39
    Yes the King Springs do fit both KE70 and AE71.
    Cheers Brett.
  1. SUBARU ff-1 chassis number(VIN)
    By 1000 Pistes in forum Subaru Garage
    Last Post: 02-06-2014, 05:55 PM
  2. crossmember to fit w50 to RA21 chassis
    By vondoom in forum Toyota Garage
    Last Post: 05-31-2013, 05:40 PM
  3. Chassis Saver - protective coating
    By Drive510 in forum Resto Tips, Wheels & Other Goodies
    Last Post: 04-11-2012, 02:05 AM
  4. SPL / SRL 311 chassis
    By Doc in forum Datsun/Nissan Garage
    Last Post: 03-14-2012, 07:46 AM
  5. S-Chassis Car Show
    By 240Z_Master in forum Events, Meets & Gatherings
    Last Post: 08-18-2010, 05:42 PM
