Results 1 to 8 of 8
Thread: 1979 Honda Prelude
    Nov 2013
    Bay Area, California
    5
    1979 Honda Prelude
    As my first true post here on JNC that isn't the intro post, I figured I'd post the reason why I joined. I recently purchased a 1979 Honda Prelude from the original owner. The car has 108k miles, all the original paper work, and even the dealer plate frames from the dealership it was originally purchased from, Walnut Creek Honda in California.
    My priority is to stop the few areas of surface rust from spreading, retune the carb since it's running a bit rich and idling a bit high, and then do a period correct resto-mod.
    What I'd change to aftermarket would be 80's bucket seats (more than likely Recaro), a Weber carb, some kind of non-OEM exhaust, and I'd try to get some kind of coilovers to fit which is going to require a lot of fab work.
    This isn't a project I look to finish in a month or two, but something over the next few years. Only the rust prevention is going to happen ASAP. Anyway, enough talk, here's some photos.
    The day I picked her up:
    And from a photo shoot I did a day or two later:
    Sep 2013
    Denver, Co.
    124
    Re: 1979 Honda Prelude
    Braulio, I just commented on your picture on the Facebook G1 Preludes page. Its good to see another Vintage Honda fan on JNC
    Jan 2008
    Melbourne, Aust.
    87
    Congratulations.
    Obviously they are prone to rust under the windscreen trims, especially if the windscreen has ever been replaced & scratched the paint!
    Might be worth checking under the wiper motor as well judging by one of mine. Have to attack around the wipers again on mine as rust must also have got between the outer panel & & wiper pivot mount as well.
    I do like those early styled steel wheels & chrome caps; '81/2 had a different design.
    Thought early VW Golf frt coilovers might be worth a look as the Prelude seemed to copy the top mount concept, adoption of 4x100 stud pattern, & the use wheel bolts rather than nuts, unlike other Honda before or after.
    Sep 2013
    Hong Kong
    771
    Very cool! 8)
    I've always admired these 1st gen. Preludes.
    Nov 2013
    5
    Thanks guys
    The cover for the wiper motors will be either repaired or replaced since the previous owner said it had rust and that's why he painted it black. I'll have to inspect it further. I've already inspected around the window by the trim and I haven't noticed anything concerning. Looks all nice and silver. I'll have to check if it has the original window or not.
    Right now I have to deal with a firing timing issue and idle speed issue. Just a bit of tuning, nothing major.
    However, my radiator fans don't seem to turn on so that's a big issue I'm focusing on right now.
    Jan 2008
    Melbourne, Aust.
    87
    Thermo-switch for the fan(s) located at the bottom of the radiator is a common item to fail eventually. Easy enough to replace.
    If you connect the two wires connecting to it together the fans will run whenever the ignition is on ensuring things won't overheat in the meantime..
    Nov 2013
    5
    Haven't checked this post in awhile so here's a long winded update (with some photos )
    Got the thermoswitch working after sourcing an NOS part, did a full radiator flush, and completely redid all the vacuum hoses. Car runs way better than the day I brought her home although I still have a few hiccups I need to solve before going for my SMOG check (which I'm already behind on :| ) Been doing a lot of restoration work and general cleaning. Cleared off 35 years worth of road grime, dirt, grease, etc. and got into polishing some bits around the car.
    After cleaning the wheel well. Struts will be changed out for BC Racing coilovers soon.
    An example of my polishing.
    And finally, just an updated pic of her rolling around town.
    Sep 2013
    Hong Kong
    771
    She looks thoroughly delicious! :wink:
    I hope you don't modify her too much - I personally love the simple OEM look of her as she is now...
  1. 1980 Honda Prelude (TX) $1200
    By Spudenater in forum Ad / Auction Finds
    Last Post: 01-17-2014, 02:14 AM
  2. Noob with 86' Honda Prelude Si
    By rexflexall in forum Introduce Yourself
    Last Post: 12-17-2013, 04:26 PM
  3. honda prelude fenders new original for sale 1e generation
    By honda-ronny in forum Honda Swap Meet
    Last Post: 12-13-2010, 11:34 PM
  4. fusible link on an '81 Honda Prelude?
    By baron von chickenpants in forum Honda Garage
    Last Post: 12-13-2010, 11:30 PM
  5. Here are my 2 Honda Prelude: 1983 and 1985
    By e-at_me in forum Honda Garage
    Last Post: 01-10-2010, 01:52 PM
