Results 1 to 10 of 15
Thread: My KGC10 Skyline 2000GT
    Dec 2008
    Lithuania
    46
    I will make a new tread instead of going in the parts source tread.
    Found it in UK. Owner was on short with the money and needed to pay restoration shop for the work they did on the car... So one mate of mine got in contact with me, and offered it. Well - i was a bit on impulsive side, and didnt asked much of the questions.. Price was 'right' and we agreed that i will take it. Its sanded to bare metal, with some parts removed. All the parts are with the car (99%), and some restoration is done (thats what owner said)...
    After few weeks - got her home. Well - wasn't quite happy - but i know that im getting in some trouble one way or another Metal work isnt new for me, because im doing restoration / and other car builds daily... But i wasn't quite sure what i will get with the skyline, because from the pictures everything looked OK.
    Here are the pictures of what i received:
    Keep in mind - all this was done at one UK restoration shop! I would not let these people no there near any car!!! Everything is done so horibly that its hard to believe some one can do a job like this, and charge money! I will need new hood. Old one was 'restored' at the front, welding some NEW metal on TOP of the old one... While doing this - outer skin of the hood got heat warped, and now is totaly out of the shape...
    Engine is stock L20 Everything looks to be in place and complete - that's a good thing
    Front fenders are in OK condition and still i will be able to restore them. Lover ends near the doors have some welding done that will need to be cut away and redone.
    https://fbcdn-sphotos-a-a.akamaihd.net/ ... 2847_n.jpg
    Heres example of HOW NOT TO DO. Awful, just awful.. Everything is WELDED on TOP of old metal in some places...
    Doors - old metal cut out, new one welded it. Heat warping is so bad that whole lower end of the doors is all messed up nd lost it shape.. After some further inspection - i found out that the new metal sheet was put in from the inside of the doors, and just welded this way, without even trying to cut the shape to butt weld both metal pieces!
    'side skirts'... They have to have a bit different shape... And worst thing - they are welded on TOP OF original ones
    Another side has the same sad story. Only good thing - is that repair on doors is done proper way. I will be able to keep drivers side door, and get ir done property...
    Another sideskirt - welded on top again Instead of cutting out / removing stock ones, and fabricating new ones on exact shape - they just did outer sheet and welded these on top of the originals Will need to remove everything and do a new sides...
    'repair' on the door jam driver side. Again - same story - why cut / replace then you can just ADD new metal ((
    Rear end. Lower part is made from new sheet metal - and welded in place. Shape is wrong, cut out for exhaust is wrong...
    Inside of the trunk - they already primered everything... Will need to cut all the'repairs out and make a new sheet metal works...
    Spare time place is done not bad... might need just some sanding / grinding and it will be ok.
    Back window lower part. common place on the Hakos. See next picture HOW they repaired it
    They slapped some scrap metal in place, and welded it from the top. WAY TO GO! Damn, how can some one do stuff like this!!!
    Floor is welded in from VW transporter! It similar shape of the hako, but the job that is done is blah Will need lots of grinding, because welds are horrible and not sanded in some places at all
    rear floor repaired with some home made sheet metal...
    Lots of parts - after checking all of them - it seems everything is in place. Im missing one fender mirror and thats all.
    Bumpers are all good, except some surface rust. Will need to re-chrome them anyway.
    So now im looking for original bonnet (stil cant decide if i should go with original or just get a FG replica...), i need left side door also... And will get on her pretty soon. Will fully dissemble everything get in on rotisserie and will start cutting all the mess...
    Also - i need help from some one who has Hako. I would need some shape traces of the rear lower parts of the fender and side skirts... If some one could help - please let me know!
    Jan 2014
    Auckland
    174
    Re: My KGC10 Skyline 2000GT
    Wow.. that's some terrible work.. I hope you give you it the restoration it deserves!
    Oct 2010
    The West Of England
    238
    That's pretty rough but there's worse Hako's around. Good luck with it.
    What part of the UK did it come from ?
    Dec 2008
    Lithuania
    46
    Quote Originally Posted by DmK66
    Birmingham
    Dec 2008
    Lithuania
    46
    Well, got one of my best metal guys that i know come and check the car with me today, so the good news is - he said he will rescue both doors, both fenders, and help me out with the trunk and rear 'pockets'. Hood - will need to be scraped. Found a stock hood already in Japan, so going to organize shipping it to me
    Now i need help about getting the right shapes formed from metal - so if any of you guys out there that have Hako could help me out - it would be greatly appreciated!!! What i need is some one that could do me a cardboard traces of these places:
    Oct 2009
    UK.
    224
    Good luck with the restoration.
    Hey I wanted to tell you. I'm going thru the same process with my 71 though I don't really update in the forum I'm very active on Instagram and most of us use that. My user name is Ri1eycoyote. Almost all of your trouble areas have manufactured replacement parts available. There are quality fender patches, lower door and rockers on YAJ where you can just buy. Cut your old trouble areas out and replace with the new. Pretty nifty. Both reasonably priced and save a lot of time.
    Dec 2008
    Lithuania
    46
    Quote Originally Posted by Ri1eyCoyote
    Saw you in Instagram Checked your pictures Im looking over YAJ, but most of the parts that pop up - are stupidly expensive considering this is just sheet metal (both side sills - 850$??)
    I got templates from one really nice guy from UK (thank you Dan!), and will get on the metal works pretty soon
    Dec 2010
    switzerland
    135
    hard to understand how somebody is able to work crappy like this!!
    good luck with your resto!!
    i have trunk lid, rear cross members and right fender for sale if you need??
    located in switzerland
    cheers
    Dec 2008
    Lithuania
    46
    Not much going on yet with my Hako, but soon it will get the much needed care
    Thanks Stev for hooking me up with a good lower part of the front fender, got my new hood also from Japan, along with a wipers cowl, and they both are in really good condition. Also bought a brand new lower panel that goes around the exhaust from KPC10 - with a small single exhaust exit And todays score is the bet one so far for me:
    This will save me SOOO much time, and end result will be just the way i want - without any stupid welds visible from the inside of the trunk, and car will get all the original shapes on the fenders
    Now just need to wait till i get them from Japan - and works will start
  1. '72 Skyline 2000GT (4-door)
    By moominsean in forum Datsun/Nissan Garage
    Last Post: 03-15-2015, 01:53 AM
  2. Docaam 72 2000GT Skyline, GC10
    By docaam in forum Datsun/Nissan Garage
    Last Post: 03-08-2015, 07:04 PM
  3. 1971 Nissan Skyline 2000GT-R $200,000
    By Zakira in forum General Discussion, JNC News & FAQ
    Last Post: 02-24-2015, 08:46 PM
  4. 1971 Nissan Skyline 2000GT For Sale
    By tomas6791 in forum Ad / Auction Finds
    Last Post: 10-29-2014, 08:05 PM
  5. 1971 Skyline 2000GT!
    By Alvin in forum Datsun/Nissan Garage
    Last Post: 01-19-2014, 11:44 AM
