Results 1 to 4 of 4
Thread: Mx73 manual swap issues
    Jun 2013
    Denver co
    26
    I'm in the middle of swapping my mx73 and have a couple issues. I am using a w58 from a mkII supra, and a mkIII drive shaft. I have seen pics in line of people doing the same swaps and mine is not looking the same. The trans is about an inch forward in the chassis, and the drive shaft carrier bearing is not matching the chassis holes. Can someone provide some insite for me?
    Jun 2013
    Denver co
    26
    Re: Mx73 manual swap issues
    Apr 2011
    TX
    283
    fix your images by using the [img] image tags
    1. i've seen a mkiii w58 in an x7 and the shifter lines up perfectly. mkii has a different shifter housing. you might want to try and find the right one vs. cutting your trans tunnel, the shifter will be banging your console in current position.
    2. on my x8, i reused the auto trans crossmember with the supra isolator bolted to it. i'm assuming you should be using your auto crossmember too, and it might need to be flipped 180 to make the bolt holes line up.
    Oklahoma City
    762
    ^ what he said. You can use the MkII W58, but the MkIII is a perfect fit. I believe that the crossmember does need to be rotated, but can't remember, it has been a few years since my last swap.
  1. Just bought a '74 Colt Gt need manual trans swap info please
    By ozzyincali in forum Mitsubishi Garage
    Last Post: 11-09-2012, 01:39 AM
  2. First Manual Swap | MX73
    By nosillallison in forum Toyota Garage
    Last Post: 02-13-2012, 02:39 AM
  3. WTB: w58 5 spd transmission and other parts for manual swap
    By corbin44 in forum Toyota Swap Meet
    Last Post: 01-02-2012, 06:50 PM
  4. '80 Toyota Celica repair manual and '99 Tacoma wiring manual
    By rrabespl in forum Toyota Swap Meet
    Last Post: 10-17-2011, 09:32 PM
  5. auto to manual tranny swap
    By ghostking in forum Toyota Garage
    Last Post: 07-15-2010, 03:45 AM
