Results 1 to 10 of 11
Thread: How To Remove 1977 Steering Wheel?
    Feb 2008
    Saratoga N.Y.
    729
    I have a 1977 GLC FA4TS that I cant get the wheel off.Does the round horn center just pop or pry off?
    May 2010
    Brisbane, QLD, Australia
    105
    Re: How To Remove 1977 Steering Wheel?
    Should be push and twist, but some earlier ones did unscrew.
    Feb 2008
    Saratoga N.Y.
    729
    Well there was a lot of movement just in and out not to turn though.
    Well I will try again till I break it. :td:
    Mar 2010
    Ballarat
    197
    Are you talking about the old 2 spoke steering wheel with the black
    centre cap? My old centre used to unclip by gentle persuasion, and it was
    a pushfit back on.
    Jun 2011
    Geelong, Australia
    63
    Is it this kind of wheel?
    If so, then you need to sort of peel the rubbery horn button off it's metal backing. You should be able to get something under the lip and it will come off pretty easily.
    Feb 2008
    Saratoga N.Y.
    729
    Yes thats the one thanks for the pic.,i did not take a pic. when i was at the jy.
    I will give it a try.
    Austin, TX
    34
    The rubber horn cap pries off easily. Use a plastic tab or a flat head screwdriver with tape wrapped on the tip.
    Under that is a 21mm nut.
    Once you get the nut off, grab the wheel at 9 and 3 o'clock then alternatively pull each side back. The wheel should pop off without using a puller.
    Feb 2008
    Saratoga N.Y.
    729
    OK that sounds about what I was trying to do.Just gonna have to give it a little more muscle.Its been sitting for 25 years.
    Feb 2008
    Saratoga N.Y.
    729
    OK it popped off but I forgot my 21mil. :roll:
    Nov 2009
    NYC
    179
    Whit, where was this?
    was it a 2door or 4 door GLC?
  1. WTB: TOM's steering wheel
    By 02Anders in forum Toyota Swap Meet
    Last Post: 12-05-2014, 04:56 AM
  2. Tom's steering wheel
    By Nic#66 in forum Universal Parts Swap Meet
    Last Post: 12-01-2013, 10:27 AM
  3. ***F/S TOM's Steering wheel and TRD RCA's***
    By jrarinas in forum Toyota Swap Meet
    Last Post: 10-20-2013, 09:45 PM
  4. Power Steering in a 1977 Celica (RA29)
    By philrSJ in forum Toyota Garage
    Last Post: 12-14-2012, 03:00 PM
  5. FS:Oem Steering Wheel
    By colt72-jay in forum Toyota Swap Meet
    Last Post: 11-14-2011, 02:01 PM
