Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: Got Me a Datsun 210
    Aug 2008
    Atl GA
    376
    Got Me a Datsun 210
    ITB's are not what i will use as i am going to do dual side draft solex carbs, but it will look very close to it, and a custom made header i will be fabricating for it after i do the engine swap in it this should be up and running by summertime, hopefully.
    Aug 2008
    Atl GA
    376
    Re: Got Me a Datsun 210
    Here is the look i am looking for, but without the body kit and 15 or 17 inch wheels that fit perfectly no hella-flush crap in my cars!!
    Aug 2008
    Atl GA
    376
    Wheels wheels wheels!
    These are my choice for now!
    Aug 2008
    Atl GA
    376
    Cleaned and put together the front end!
    Sep 2013
    Hong Kong
    771
    Please, Please, Please.... tell me you're going to keep those awesome "210" decals down the sides...
    Soooooo retro!! 8)
    I'd love to get some old Datsun to keep my '77 Trueno company... :wink:
    Apr 2009
    South Dakota,USA
    22
    if that was mine one of the first things id look into is some jdm bumpers
    Aug 2008
    Atl GA
    376
    Both advises above are a yes and a MUST!
    Thanks guys!
    here is what i was trying to get from Japan!
    Nov 2010
    Florida, USA
    48
    Why not keep the ITB's? What are the spec's on the motor?
    Aug 2008
    Atl GA
    376
    Quote Originally Posted by floridaguy
    i want to keep it non EFI, something different than the usual SR20,
    The engine is all stock 145 to 165 JDM first gen SER powerplant, maybe a upgraded sr16 hi comp pistons head port tomei solid lifter rev kit and hi rev cams will be ready by the time i need to rebuilt the engine, but way down the road!
    Aug 2008
    Atl GA
    376
    Ok here is somethin i do last nighet when imsomnia attacks,
    Went downstaresand start mocking up the engine tranny combo,
    If you are familiar with Nissan u must know SR20 block castings are different from FWD to RWD
    But u can use the FWD one in RWD with some modifications but you cant do the other way around!
    You need to trim all that to get the RWD starter on its place,
    Then in order to atach the tranny on that side a heavy duty bracket need to be fabricated, and that bracket is bolted to the side of the block and goes back to the tranny bellhousing under the starter, this bracket must be minimum 3/8 thick steel or 1/2 inch aluminum,
    It will be cool and super strong, this way any SR20 block could be used and i dont have to be obligated to use the ABUSED RWD blocks only!
    Ps
    By the way those mods is only on the starter side cuz the other side it a prfect fit!
    Pss
    And Just in case you guys ask or worried about the amount of material to be removed from the block,,,
    Is not that much for real, the RWD casting do not have the starter ring whatsoever and the only difference is the lower ear for bellhousing attachment is in a lower position, thats it, i am just replacing the lower ear with a fabricated bracket that bolts to the engine block next to the motor mount bracket and maybe 3 or 4 oil pan bolts all together,
    I do drill one hole on the tranny bell to acomodate the top right hand bolt and use a spacer betwine the tranny bell and the engine cuz the bell is hollow there,
    But here is a rugh sketch of what that bracket will look like!
    By the way the top bracket is not necesary but i just trow it out there just in case someone ask!
