Page 1 of 6 123 ... LastLast
Results 1 to 10 of 58
Thread: My 1974 929 - New to the garage
    Nov 2009
    Adelaide
    416
    Since the forum crash a few weeks ago, I have noticed that my thread has vanished....so here is a new one.....I have included updates thus far as well.
    Prior to the departure of my coupe, I started looking around at what I would replace it with if I decided to sell. After a bit of research I had my heart set on an FD RX7....after looking at a few examples and a couple of test drives I was set to sell my coupe and buy an FD......or so I thought.....
    My coupe went up for sale and subsequently sold very quickly......and I had my eye on a very tidy Montego blue FD that was a local car......and then this came up for grabs.....
    So here it is...my 1974 Mazda 929!
    A quick rundown of the car as purchased:
    ’74 929 flat front sedan rebuilt to RX4 spec
    Fresh 13B Extend port – RX4 housings, 12A irons – all new parts and seals used in rebuild
    48IDA Weber and K&N filter – Facet lift pump, surge tank, Carter main pump, 3/8 fuel lines
    Thick wall full twin system, 2 resonators, exhaust merges over diff into rotaflow muffler
    Custom alloy radiator and oil cooler (seriously HUGE) 16 inch thermo fan and braided lines
    Rebuilt RX7 5 speed, heavy duty clutch, reconditioned tailshaft, rebuilt diff
    Resprayed in a slightly different tint of factory Mazda blue, new glass, rubbers and clips
    Original interior with new carpet and seat belts, RX4 Dash cluster
    Overall very happy with my new toy!! The car is a credit to it’s previous owner.
    But as with all my projects it quickly developed a “To do” list!
    So far I have made a few changes to the car, mostly around detail.
    First up was a major detail clean – inside, outside, underneath and places never seen!!
    The interior was first as the white vinyl was quite grubby. Meguiars leather and vinyl cleaner (an entire bottle!!) followed by 2 liberal treatments of Meguiars leather treatment had it looking like new again. The dash and everything else also copped a good clean. I have also fitted my MOMO Sistema steering wheel, a new yellow and black gear knob and some autometer gauges to keep an eye on things. All door trims were removed and the doors treated with fish oil. To complete the Grandpa look I have decked out the back seat with a tartan rug which belonged to my recently deceased Grandfather.
    The exterior copped a thorough clean with most bits like tail lights, grille etc all removed for a detail clean. After that it got a few paint chip touch ups, all stainless and chrome polished, paint polished followed by 2 coats of wax. Some new badges were fitted at reassembly time including the RE12 badges as well as a set of RX4 badges for the rear quarters. I also rubbed back and resprayed the pillar between the windows on the back doors in charcoal grey as well as the rear quarter vents. Whilst they were apart, I removed the remnants of old resin in the vent badges as well as the resin in the grille badge and rotor shaped boot lock cover. These all then got new resin put in and put back on the car. Having never done this before, I am quite happy with the result!
    The engine bay has had a fair bit of wiring removed and the remainder tidied up for a neater appearance. I also rewired the coils. Some new blue leads and separators, radiator cap, oil filler cap, dissy cap, rotor button and a few other bits have also been done. Future plans include a complete rewire of the engine bay, hiding as much as possible. I also gave the oil cooler a coat or two of satin black as I didn’t like how obvious it was from the front.
    A bit of surface rust was found in the spare tyre well, so it was rubbed back, treated, primed and resprayed. The car still has an original 175SR13 whitewall spare tyre, mint boot mat and jack installed. The rear quarters were fish oiled.
    New tyres have been fitted as the old ones were showing signs of cracking on the sidewalls...Fitted a set of Kumhos, as I have never had a bad set of these.....unfortunately a few minutes after picking the car up I was overtaken by one of my hubcaps.....which rolled into the intersection and got run over!! Luckily I found a MINT pair on ebay and replaced the missing one...also have a spare now. I also got new whitewalls done as it didn’t look quite right without them.
    There is a stack more, but I won’t bore you with every minor detail. I will let the pics do the talking..
    Dec 2007
    Amstedam, The Netherlands
    40
    Re: My 1974 929 - New to the garage
    Good to see your topic again Your 929 looks awesome. You don't have the pictures in a bigger size? These look like thumbnails
    Nov 2009
    Adelaide
    416
    Thanks! The forum spat out my normal 800x600 pics and said I needed to go smaller....I will try the next size up.
    Sep 2011
    Adelaide
    347
    Sick! :tu:
    Jul 2012
    Adalaide, Australia
    89
    Benn Car looks good mate. Your list was large but looks like you got through it and and made this car your own
    when it come time to do your engine bay rewire let me know. i will do you a copy of the wiring diagrams i have and give you some pointer of what can be removed (which is quite a few wires) should tidy the bay up nicely
    i really should chuck up a thread of my car on here
    Nov 2009
    Adelaide
    416
    Thanks Matt. Yeah I wanted to make some changes to make it more my own. Still a bit to go....
    Will definately hit you up when it comes time to do the bay. Will weld up a few unused holes an respray it at the same time. Also want to paint the engine the same blue as it is different at the minute.
    Also have a small rust bubble on the rear quarter that I want to get done after Christmas.
    Really enjoying the car, it has done plenty of Kms without issue so far! Looking forward to the birthday cruise
    You should throw a thread up on your car...from the early days to now...you sure have done some work over the years.
    Apr 2011
    sydney NSW
    112
    Nice
    Which is better to drive? 7 or 4
    Nov 2009
    Adelaide
    416
    Quote Originally Posted by Ontrack
    Nice
    Depends on what I'm doing / where I am going....the 7 is much easier to drive as it's totally stock mechanically...goes around corners better, stops better but is pretty cramped.....at 6 foot 3 there is not much head room. Pretty relaxed car to drive fast and great fun on windy roads in the hills...only drawback is lack of outright grunt. The 7 is a lot more stealth. Not many people look at it....which is good
    The 4 is harder to drive with the weber, but goes a shit load harder! It loves lighting the tyres up. It's a great cruiser, with plenty of room in it. I can chuck the wife and both kids in this one and go anywhere. Not great in corners and it attracts too much attention wherever it goes.
    To be honest I think if I put the RX4's engine and weber in the RX7, I would probably have the ideal car....then I could put a Bridgeport in the 4!
    Jun 2009
    Melbourne, Australia
    802
    you know... Some Cheviot Raiders in gold would look perfect with the blue! :mrgreen:
    Nov 2009
    Adelaide
    416
    Not knowing what they looked like, I googled them....spot on, they would look awesome!!
    I have been contemplating some gold 15 inch superlites / rota rb's...
    There as a set of superlites here in sa for sale a while back....was going to get them for the RX7 and changed my mind as I like the stock ness about the 7....wish I had bought them now!
  1. my new garage
    By hugla in forum Mitsubishi Garage
    Last Post: 10-11-2013, 11:01 PM
  2. Toyota in your garage...
    By groupb in forum Toyota Garage
    Last Post: 01-07-2013, 10:09 PM
  3. Garage Sale
    By garageStar in forum Other Marques Swap Meet
    Last Post: 06-17-2011, 07:12 AM
  4. T Y in My Garage
    By pomphy in forum Toyota Garage
    Last Post: 06-15-2010, 04:41 AM
  5. Micky's Garage
    By Micky in forum Mazda Garage
    Last Post: 08-14-2009, 08:49 PM
