Results 1 to 2 of 2
Thread: Brake Master Cylinder for '71 Toyota Crown MS75
    Oct 2013
    6
    Trying to track down either a rebuild kit or rebuild Brake Master Cylinder for my '71 Crown MS75. Any leads appreciated!
    Mar 2007
    Pacific
    91
    Re: Brake Master Cylinder for '71 Toyota Crown MS75
    When searching, best to say '72 so not to be confused with MS50 series; also use MS65 as that's more common & the same.
    Toyota rebuild kits 04493-30010 & 004493-30012 are hard to find nowadays.
    You can always roll the dice with the generics such as:
    http://www.ebay.com/itm/300952181808
    Maybe best to use one of the Hemmings listed classic car brake rebuilders as they are good in guaranteeing their work.
    Good luck!
  1. Replies: 7
    Last Post: 10-05-2013, 03:42 AM
  2. Help needed on 1971 toyota crown brake master cylinder
    By EODoherty in forum Toyota Garage
    Last Post: 12-05-2012, 02:35 AM
  3. WTB: factory mazda rx-3 master brake cylinder or rebuild kit
    By rotary_coupe in forum Mazda Swap Meet
    Last Post: 11-24-2011, 07:23 PM
  4. replacement brake master cylinder for 70 corona
    Last Post: 06-14-2011, 01:53 AM
  5. Toyota RT72 brake master cylinder
    By mark corona II in forum Toyota Garage
    Last Post: 11-15-2010, 06:10 PM
