Results 1 to 5 of 5
Thread: Help! This is driving me crazy!! MX32
    Sep 2012
    Missoula, Montana
    38
    I have a 79 MX32 and am having the weirdest electrical issues. I have no power to my gauges, blower motor, or rear defog; but my wipers, radio and all lights work. I have 12 volts to all fuses at the fuse box and I have replaced the ignition switch. Charge light is lit VERY dimly. Alternator checks out at 14.2 volts running and battery is new (12.4 volts with engine off). Any ideas?
    Nov 2010
    NC
    289
    Re: Help! This is driving me crazy!! MX32
    Corrosion in/on the fuse panel causes ridiculous electrical issues that make absolutely no sense sometimes.
    Apr 2011
    TX
    283
    lucky for you there's minimal wiring to trace. time to go through it all.
    Aug 2013
    Inland empire , California
    13
    I had a problem similar to that with the brake lights on my corona..and after checking it with a probe tester and then a volt meter I seen that it wasn't enought power going thru so I used fine grit sand paper and cleaned the connections on the panel and it worked fine after that .
    Hope this helps
    Sep 2012
    Missoula, Montana
    38
    Thank you. I'll give it a try.
  1. Looking for some crazy 4x114.3 wheels
    By hitmancody2130 in forum Wheels Swap Meet
    Last Post: 05-06-2013, 03:46 AM
  2. s12 is driving me crazy, whats wrong?
    By kidrobot27 in forum Datsun/Nissan Garage
    Last Post: 04-10-2012, 05:27 AM
  3. Crazy man needs opinons
    By Vaxx in forum Introduce Yourself
    Last Post: 11-08-2011, 03:47 AM
  4. Crazy Ray's MD - Hey colhogen, look familiar?
    By djlotus in forum Junkyard Finds
    Last Post: 07-07-2011, 03:41 AM
  5. Crazy ray's MD.
    By brownmagic in forum Junkyard Finds
    Last Post: 02-13-2011, 02:38 AM
