Results 1 to 7 of 7
Thread: 4ac to 4age
    Jun 2008
    ohio us
    102
    4ac to 4age
    Is there any bolt on between the motors like exhaust manifold or exhaust system I have an 1983 sr5 liftback and I'm looking at exhaust systems for it it is the same block no?
    Oklahoma City
    762
    Re: 4ac to 4age
    Same block, but completely different head. Hence, completely different parts for headers and such
    Jun 2008
    ohio us
    102
    Re: 4ac to 4age
    How much would I need to convert over besides motor and ecu?
    Jun 2013
    6
    Re: 4ac to 4age
    Quote Originally Posted by zakte72
    Motor
    Harness
    Ecu
    Fuel pump
    Fuel lines
    Transmission bell housing or 4AGE T50
    Clutch lines
    Slave cylinder
    Jun 2008
    ohio us
    102
    Re: 4ac to 4age
    What's an easier set conversion 4age or a 3tc set up?
    Apr 2011
    TX
    283
    Re: 4ac to 4age
    dude. going from carb engine to carb engine means you don't have to deal with swapping the fuel system. other than that it's the same thing. "easier" is a subjective thing, might be a weekend and a case of beer for one guy or a month-long headache full of forum hand-holding and ending up with trailering the whole thing to a shop and having them finish it for another. you seem like you're in danger of becoming the latter.
    google is your friend:
    http://www.dorikaze.net/showthread.php? ... -into-AE86
    GTS swaps into SR5 cars are seriously well documented in many places.
    Dec 2008
    Massachusetts
    38
    Re: 4ac to 4age
    3tc is the cheaper route unless you can score a gts donor car for cheap which are hard to come by as parts pull a premium. Keep in mind that even if you pick up a 4age off an mr2 for cheap there is a few parts that are needed to convert to rwd. Do your homework as it can get expensive. Good Luck. Any pictures of car.
  1. 4AGE 16v smallport RWD AE86 full setup + extra 4AGE bluetop
    By elevenrussians in forum Toyota Swap Meet
    Last Post: 10-19-2014, 02:06 AM
  2. F/S t50 4age bellhousing
    By MrFrosty in forum Toyota Swap Meet
    Last Post: 05-22-2014, 09:16 PM
  3. FS: 4AGE 20v Blacktop w/ MT ECU.
    By 3f05q in forum Toyota Swap Meet
    Last Post: 09-22-2013, 05:37 PM
  4. 4age
    By juice in forum Toyota Swap Meet
    Last Post: 12-10-2011, 08:53 PM
  5. KE70 + 4age help!
    By j.c grime in forum Toyota Garage
    Last Post: 11-09-2009, 06:51 AM
